I set the z height at 120 even though its a bit higher otherwise the build plate just crashes into the hotend even with the probe triggering it will still crash.
This is a N grid of 3 x 3.
13:20:54.321 : Info:Autoleveling disabled
13:21:25.305 : Z-probe:16.750 X:70.00 Y:70.00
13:21:46.487 : Z-probe:17.907 X:70.00 Y:155.00
13:22:10.631 : Z-probe:19.047 X:70.00 Y:240.00
13:22:34.293 : Z-probe:16.887 X:155.00 Y:70.00
13:22:55.533 : Z-probe:17.966 X:155.00 Y:155.00
13:23:19.640 : Z-probe:19.035 X:155.00 Y:240.00
13:23:43.485 : Z-probe:17.071 X:240.00 Y:70.00
13:24:04.889 : Z-probe:18.091 X:240.00 Y:155.00
13:24:29.287 : Z-probe:19.104 X:240.00 Y:240.00
13:24:29.291 : plane: a = 0.0011 b = 0.0127 c = 15.8450
13:24:32.527 : Printer height:122.00
13:24:32.527 : CurrentZ:15.85 atZ:13.85
13:24:57.346 : Z-probe:16.292 X:70.00 Y:70.00
13:25:19.193 : Z-probe:18.571 X:70.00 Y:155.00
13:25:52.458 : Z-probe:20.862 X:70.00 Y:240.00
13:26:15.743 : Z-probe:16.438 X:155.00 Y:70.00
13:26:37.573 : Z-probe:18.560 X:155.00 Y:155.00
13:27:10.108 : Z-probe:20.719 X:155.00 Y:240.00
13:27:33.511 : Z-probe:16.626 X:240.00 Y:70.00
13:27:55.632 : Z-probe:18.644 X:240.00 Y:155.00
13:28:28.083 : Z-probe:20.714 X:240.00 Y:240.00
13:28:28.087 : plane: a = 0.0005 b = 0.0254 c = 14.5921
13:28:33.944 : Printer height:122.74
13:28:33.947 : CurrentZ:14.59 atZ:13.85
This will continue iterating the same changes. Pushing the build plate further from flat. So if its negative it will make it more negative and if its positive it will make it more positive. The x and y positions are about where they need to be in physical space.
