hi
Repetier host crashes on my pc when i sliced with Slic3r.
Steps:
- load the gcode file (as example see link below)
- try to zoom-in/zoom-out with wheel
Also it creashes immediatelly after a model sliced.
PC:
Windows 10 pro x64, 1709 16299.192
Graphics - on board Intel HD 3000 in Core i7 2600K
STL:
https://drive.google.com/open?id=1taZkUBap93edxAVGjujmfIik9kjdLP3f<br/><br/>Gcode:<br/>https://drive.google.com/open?id=1zQwIqV2EWzwsf4qtyY1F9B4XpkpDfBgA<br/><br/>Screenshots:<br/><br/><img alt="" src="https://forum.repetier.com/uploads/editor/fd/29h83xeap5jg.jpg" />
<a rel="nofollow" target="blank" title="Link: null">
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0b77a5c561934e089\mscorlib.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\RepetierHost.exe'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0b77a5c561934e089\System.Windows.Forms.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0b77a5c561934e089\System.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0b03f5f7f11d50a3a\System.Drawing.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\RepetierHostExtender.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0b03f5f7f11d50a3a\System.Configuration.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0b77a5c561934e089\System.Core.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0b77a5c561934e089\System.Xml.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\OpenTK.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms.resources\v4.0_4.0.0.0_ru_b77a5c561934e089\System.Windows.Forms.resources.dll'. Module was built without symbols.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0b03f5f7f11d50a3a\Accessibility.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\ColorSlider.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\plugins\CuraEngine\CuraEngine.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\plugins\RepetierServerConnector\RepetierServerConnector.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\plugins\RRFirmwares\RRFirmwares.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\plugins\SlicerSlic3r\SlicerSlic3r.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\plugins\SlicerSlic3rPE\SlicerSlic3rPE.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceProcess\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\Newtonsoft.Json.dll'. Cannot find or open the PDB file.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\Program Files\Repetier-Host\OpenTK.GLControl.dll'. Module was built without symbols.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\mscorlib.resources\v4.0_4.0.0.0_ru_b77a5c561934e089\mscorlib.resources.dll'. Module was built without symbols.
'RepetierHost.exe' (CLR v4.0.30319: RepetierHost.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.resources\v4.0_4.0.0.0_ru_b77a5c561934e089\System.resources.dll'. Module was built without symbols.
The thread 0x25f8 has exited with code 0 (0x0).
Exception thrown: 'System.AccessViolationException' in OpenTK.dll
Попытка чтения или записи в защищенную память. Это часто свидетельствует о том, что другая память повреждена.
Windows event log message in xml format:
<Event
xmlns="http://schemas.microsoft.com/win/2004/08/events/event</b>"><br/>-</a> <System>
<Provider Name="Application Error"
<EventID
Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-01-13T11:58:56.535842100Z" />
<EventRecordID>2999</EventRecordID>
<Channel>Application</Channel>
<Computer>vb-homepc</Computer>
<Security />
</System>
<a rel="nofollow" target="_blank">-</a> <EventData>
<Data>RepetierHost.exe</Data>
<Data>1.0.0.0</Data>
<Data>597f4ac2</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.16299.15</Data>
<Data>4736733c</Data>
<Data>c000041d</Data>
<Data>00000000000b67e2</Data>
<Data>e3c</Data>
<Data>01d38c65a5edb319</Data>
<Data>C:\Program Files\Repetier-Host\RepetierHost.exe</Data>
<Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data>0b6c286a-ffa3-466a-abd5-1a3b8c4e497a</Data>
<Data />
<Data />
</EventData>
</Event>
