Have another question I have E0 setup for the extruder motor, I can't get the motor to move, tested the motor on X axis and it worked put in a new driver and it locks the motor on e0, but can't get it to go anywhere checked the eeprom setting and don't see ext.0 only ext.1 is this correct I don't see a way to clean or overwrite this. I then disabled the eepromto load from the config that has only e0 enabled but still no motor movement..
Thanks gary
