WardMD90745 said:
tpbh said:
Success. Thank you!
I want to put the layer on my LCD screen. With M117 however it only briefly flashes on is there a way to keep it permanently on the screen for prints where the filament to be changed so I can monitor via web cam.
I haven't tried it yet (I'm in the middle of a large/long print), but I'm adding the ability to specify the text (as you would in the M117 command) to the M600 (Filament Change) command.
M600 Load Blue Filament
In theory, this would update the "status" (after the Filament Change menu is displayed) to "Load Blue Filament"...
I'll update the post, if the change (hack) works!
I was successful in adding "comments" to the M600 command (like M117).
With this change, one can pass "comments" as described above.
The only caveat, is the "comment" remains when you exit from the Filament Change menu...
You can, of course, follow your M600 with an M117 to set a new (or blank) comment in the status line.
