just can tell you what i did at the beginning..
i took calibrated thermocouple and removed the nozzle to measure inside the heater block.
absolute nonsens. why?
the filament temperature will never be the same, it usually is not long enough in the heater to reach heaters temperature( depending on printing speed, layer height, nozzle size etc...)
it just heats up, you never know exact temperature.
The temperature reading is just something "over the thumb" so at the end you have to find the setting for
your filament on your printer.
