warlock2511 Hello, Repetier Server looses the order of Printers I connected. Is there any issue, that if I Power on on single device, not Printer 1 and 2 got "connection" at the same time..?
Repetier This is the host thread!If you have 2 printers under linux I guess they can switch position since order of activation matters here. Do not use /dev/ttyxxx in this case but use /dev/serial/by-path/... so it matters on which usb port they are connected. Then assignment stays the same.
