I've been completely unable to make it work as expected. The extruder always reverses at some point no matter the value selected with M233 Y0 to M233 Y50. Even with a M233 Y1 value the extruder will reverse after a few seconds and eventually will return to moving forward.
I modified a M900 gcode file to test the various values but it always retracts and then when it does start to go forward there is nothing in the nozzle to extrude.
I only have advance enabled in the firmware. Quadratic is disabled. M233 only echoes back the Y value for L.
Here is the gcode file I am testing with. Even if I remove the M233 commands and manually set it to a value before a print any value above 0 will reverse the extruder.
M107
M83 ; extruder relative mode
M104 S210 ; set extruder temp
M140 S55 ; set bed temp
M190 S55 ; wait for bed temp
M109 S210 ; wait for extruder temp
M233 Y0 ;set advance to 0 to start
G28 W ; home all without mesh bed level
G80 ; mesh bed leveling
G1 Y3.0 F1000.0 ; go outside print area
G1 X60.0 E9.0 F1000.0 ; intro line
G1 X100.0 E12.5 F1000.0 ; intro line
G21 ; set units to millimeters
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G1 Z0.200 F200.000
M204 S500
;20mm/s = F1200
;70mm/s = F4200
;120mm/s = F7200
G1 E-0.80000 F2100.00000
G1 X10 Y10 F7200.000
G1 E0.80000 F2100.00000
M233 Y0
G1 X10 Y20 E0.37418 F1200 ;Prime, travel to first testline
G1 X30 Y20 E0.74835 F1200 ;Slow part
G1 X60 Y20 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X80 Y20 E0.74835 F1200 ;Slow part
M233 Y5
G1 X80 Y30 E0.37418 F1200 ;Travel to next testline
G1 X60 Y30 E0.74835 F1200 ;Slow part
G1 X30 Y30 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X10 Y30 E0.74835 F1200 ;Slow part
M233 Y10
G1 X10 Y40 E0.37418 F1200 ;Travel to next testline
G1 X30 Y40 E0.74835 F1200 ;Slow part
G1 X60 Y40 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X80 Y40 E0.74835 F1200 ;Slow part
M233 Y15
G1 X80 Y50 E0.37418 F1200 ;Travel to next testline
G1 X60 Y50 E0.74835 F1200 ;Slow part
G1 X30 Y50 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X10 Y50 E0.74835 F1200 ;Slow part
M233 Y20
G1 X10 Y60 E0.37418 F1200 ;Travel to next testline
G1 X30 Y60 E0.74835 F1200 ;Slow part
G1 X60 Y60 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X80 Y60 E0.74835 F1200 ;Slow part
M233 Y25
G1 X80 Y70 E0.37418 F1200 ;Travel to next testline
G1 X60 Y70 E0.74835 F1200 ;Slow part
G1 X30 Y70 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X10 Y70 E0.74835 F1200 ;Slow part
M233 Y30
G1 X10 Y80 E0.37418 F1200 ;Travel to next testline
G1 X30 Y80 E0.74835 F1200 ;Slow part
G1 X60 Y80 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X80 Y80 E0.74835 F1200 ;Slow part
M233 Y35
G1 X80 Y90 E0.37418 F1200 ;Travel to next testline
G1 X60 Y90 E0.74835 F1200 ;Slow part
G1 X30 Y90 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X10 Y90 E0.74835 F1200 ;Slow part
M233 Y40
G1 X10 Y100 E0.37418 F1200 ;Travel to next testline
G1 X30 Y100 E0.74835 F1200 ;Slow part
G1 X60 Y100 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X80 Y100 E0.74835 F1200 ;Slow part
M233 Y45
G1 X80 Y110 E0.37418 F1200 ;Travel to next testline
G1 X60 Y110 E0.74835 F1200 ;Slow part
G1 X30 Y110 E1.12253 F4200 ;Accelerate - cruise - decelerate
G1 X10 Y110 E0.74835 F1200 ;Slow part
M107
G4 ; wait
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
G91; relative cooridantes
G1 Z1 F200;
G90; set absolute coordinates
G1 X0 Y170 F5000; home X axis
M84 ; disable motors
