Hello at all!
i have a strange problem, while i attempt to print an object. the first time i tried to print the object, no error occured. at the second time, ca. 50 % of the object has been printed, until the error appeared. After retrying, the error always appeared at the exactly same position, every time i tried to reprint the object.
The error message is: extruder 0: temp sensor defect. At the temperature measurement in repetier- host, the fall-off is very clearly, but just for a few seconds, afterwards the temperature is at the setpoint again. A few moments later, the temperature fall off again and the printer goes to "dry run mode" (or somehow). That means he's going on with the job, but without extruding filament.
After a reset of the printer, i can start the job again and in the first moment, i don't have any temperature issues.
After a few retries, i printed an other object, using the same slicer- settings, without any problems!
Then i went back to the "problem- object" and tried again, but without any succsess, and with the exactly same error. i also tried it, after rotating the object 90?? - but the same error occured.
error1:
16:19:02.915 : ok 1761
16:19:02.916 : N1762 G1 X62.406 Y25.302 E232.4866111
16:19:02.939 : ok 1762
16:19:02.940 : N1763 G1 X63.134 Y24.144 E232.5602103
16:19:02.964 : ok 1763
16:19:02.964 : N1764 G1 X64.113 Y23.159 E232.63588
16:19:02.984 : ok 1764
16:19:02.985 : N1765 G1 X65.288 Y22.415 E232.709899
16:19:02.989 : ok 1765
16:19:02.989 : N1766 G1 X66.57 Y21.962 E232.783103
16:19:03.009 : ok 1766
16:19:03.009 : N1767 G1 X66.614 Y21.945 E232.785698
16:19:04.374 : extruder 0: temp sensor defect
16:19:04.374 : heated bed: working
16:19:04.378 : Error:Printer set into dry run mode until restart!
16:19:05.475 : ok 1767
16:19:05.475 : N1768 G1 X67.969 Y21.794 E232.8589107
16:19:05.499 : ok 1768
16:19:05.500 : N1769 G1 X216.012 Y21.791 E240.827882
16:19:05.520 : ok 1769
16:19:05.520 : N1770 G1 X217.382 Y21.945 E240.902104
16:19:05.524 : ok 1770
16:19:05.524 : N1771 G1 X218.657 Y22.391 E240.974793
16:19:05.545 : ok 1771
16:19:05.545 : N1772 G1 X218.697 Y22.406 E240.977111
16:19:05.565 : ok 1772
16:19:05.565 : N1773 G1 X219.855 Y23.134 E241.050681
16:19:05.590 : ok 1773
16:19:05.590 : N1774 G1 X220.84 Y24.113 E241.1254107
16:19:05.614 : ok 1774
16:19:05.615 : N1775 G1 X221.584 Y25.288 E241.200292
16:19:05.618 : ok 1775
16:19:05.619 : N1776 G1 X222.037 Y26.57 E241.273496
16:19:05.635 : ok 1776
16:19:05.635 : N1777 G1 X222.054 Y26.614 E241.276100
16:19:09.436 : ok 1777
16:19:09.436 : N1778 M10530
16:19:09.461 : ok 1778
16:19:09.461 : N1779 G1 X222.206 Y27.969 E241.349385
16:19:09.481 : ok 1779
16:19:09.488 : N1780 G1 X222.209 Y256.012 E253.6244103
16:19:09.535 : T:213.04 /210 B:70.16 /70 B@:0 @:0
16:19:09.535 : ok 1780
16:19:09.535 : N1781 G0 X222.628 Y256.035 F4200126
16:19:09.538 : ok 1781
16:19:09.538 : N1782 G1 X222.465 Y257.476 E253.7025 F18005
16:19:09.542 : ok 1782
16:19:09.543 : N1783 G1 X222.001 Y258.802 E253.7781100
16:19:09.547 : ok 1783
16:19:09.547 : N1784 G1 X221.969 Y258.887 E253.78395
16:19:09.550 : ok 1784
16:19:09.551 : N1785 G1 X221.195 Y260.117 E253.8612111
16:19:09.575 : ok 1785
16:19:09.575 : N1786 G1 X220.15 Y261.169 E253.941109
16:19:09.579 : ok 1786
16:19:09.580 : N1787 G1 X218.895 Y261.964 E254.02190
16:19:09.596 : ok 1787
16:19:09.596 : N1788 G1 X217.573 Y262.43 E254.096488
16:19:12.066 : ok 1788
16:19:12.066 : N1789 G1 X217.486 Y262.464 E254.1015109
16:19:12.086 : ok 1789
16:19:12.086 : N1790 G1 X216.054 Y262.625 E254.17982
16:19:12.110 : ok 1790
16:19:12.114 : N1791 G1 X67.965 Y262.628 E262.150392
16:19:12.119 : ok 1791
16:19:12.119 : N1792 G1 X66.523 Y262.465 E262.228581
16:19:12.131 : ok 1792
16:19:12.131 : N1793 G1 X65.197 Y262.001 E262.304100
16:19:12.156 : ok 1793
16:19:12.156 : N1794 G1 X65.112 Y261.969 E262.309103
16:19:12.180 : ok 1794
16:19:12.181 : N1795 G1 X63.882 Y261.195 E262.387295
16:19:12.201 : ok 1795
16:19:12.201 : N1796 G1 X62.83 Y260.15 E262.467103
16:19:12.205 : ok 1796
16:19:12.205 : N1797 G1 X62.035 Y258.895 E262.54799
16:19:12.225 : ok 1797
16:19:12.226 : N1798 G1 X61.565 Y257.562 E262.623100
16:19:16.043 : ok 1798
16:19:16.043 : N1799 M10517
16:19:16.068 : ok 1799
16:19:16.068 : N1800 G1 X61.535 Y257.486 E262.627484
16:19:16.109 : ok 1800
16:19:16.116 : N1801 G1 X61.375 Y256.054 E262.705104
16:19:16.143 : T:27.07 /210 B:69.67 /70 B@:0 @:0
16:19:16.144 : ok 1801
16:19:16.144 : N1802 G1 X61.372 Y27.965 E274.982596
16:19:16.150 : ok 1802
16:19:16.150 : N1803 G1 X61.534 Y26.524 E275.0606106
16:19:16.153 : ok 1803
16:19:16.154 : N1804 G1 X61.998 Y25.197 E275.1363111
16:19:16.158 : ok 1804
16:19:16.158 : N1805 G1 X62.03 Y25.112 E275.141189
16:19:16.182 : ok 1805
16:19:16.182 : N1806 G1 X62.804 Y23.882 E275.2194104
16:19:16.207 : ok 1806
16:19:16.207 : N1807 G1 X63.849 Y22.83 E275.299287
16:19:16.227 : ok 1807
16:19:16.228 : N1808 G1 X65.104 Y22.035 E275.3792108
16:19:16.231 : ok 1808
16:19:16.232 : N1809 G1 X66.426 Y21.569 E275.4546104
16:19:16.256 : ok 1809
16:19:16.256 : N1810 G1 X66.513 Y21.535 E275.459699
16:19:18.722 : ok 1810
16:19:18.722 : N1811 M10530
16:19:18.746 : ok 1811
16:19:18.747 : N1812 G1 X67.946 Y21.375 E275.537398
16:19:18.792 : ok 1812
16:19:18.798 : N1813 G1 X216.035 Y21.372 E283.508594
16:19:18.836 : T:-20.00 /210 B:69.55 /70 B@:0 @:0
16:19:18.836 : ok 1813
16:19:18.836 : N1814 G1 X217.475 Y21.534 E283.586590
16:19:18.840 : ok 1814
16:19:18.840 : N1815 G1 X218.802 Y21.998 E283.662292
16:19:18.844 : ok 1815
16:19:18.844 : N1816 G1 X218.887 Y22.03 E283.6671108
16:19:18.849 : ok 1816
16:19:18.849 : N1817 G1 X220.117 Y22.804 E283.745390
16:19:18.852 : ok 1817
16:19:18.852 : N1818 G1 X221.169 Y23.849 E283.825293
16:19:18.869 : ok 1818
16:19:18.869 : N1819 G1 X221.964 Y25.104 E283.905195
16:19:18.873 : ok 1819
16:19:18.873 : N1820 G1 X222.427 Y26.418 E283.980190
16:19:18.893 : ok 1820
16:19:18.894 : N1821 G1 X222.464 Y26.513 E283.985684
16:19:22.695 : ok 1821
16:19:22.696 : N1822 M104 T0 S024
16:19:22.716 : ok 1822
16:19:22.717 : N1823 M140 S093
16:19:22.740 : ok 1823
16:19:22.740 : extruder 0: working
16:19:22.740 : N1824 G1 X0 Y0 F5000117
16:19:22.745 : heated bed: working
16:19:22.745 : Error:Printer set into dry run mode until restart!
16:19:22.745 : extruder 0: working
16:19:22.748 : Error:Printer set into dry run mode until restart!
16:19:22.748 : ok 1824
16:19:22.749 : N1825 M8433
16:19:22.752 : ok 1825
16:19:22.752 : N1826 M10526
16:19:22.756 : ok 1826
16:19:27.677 : N1827 M10527
16:19:27.799 : ok 1827
16:19:27.834 : T:202.54 /210 B:68.77 /70 B@:0 @:0
16:19:27.848 : T:202.54 /210 B:68.77 /70 B@:0 @:0
16:19:28.802 : wait
16:19:29.801 : wait
16:19:30.801 : wait
16:19:31.805 : wait
16:19:32.699 : N1828 M10520
16:19:32.702 : ok 1828
16:19:32.732 : T:198.75 /210 B:68.48 /70 B@:0 @:0
16:19:33.078 : N1829 G1 Z10.3 F20040
16:19:33.083 : ok 1829
16:19:33.271 : N1830 G1 Z20.3 F20035
16:19:33.275 : ok 1830
16:19:33.463 : N1831 G1 Z30.3 F20035
16:19:33.468 : ok 1831
16:19:34.467 : wait
16:19:35.466 : wait
16:19:36.470 : wait
16:19:37.470 : wait
16:19:37.728 : N1832 M10531
16:19:37.732 : ok 1832
16:19:37.760 : T:195.00 /210 B:68.23 /70 B@:0 @:0
16:19:38.731 : wait
16:19:39.735 : wait
16:19:40.734 : wait
16:19:41.734 : wait
error2:
16:35:27.290 : N3372 G1 X64.113 Y23.159 E232.63589
16:35:27.307 : N3373 G1 X65.288 Y22.415 E232.709898
16:35:27.311 : N3374 G1 X66.57 Y21.962 E232.78398
16:35:27.319 : N3375 G1 X66.614 Y21.945 E232.7856103
16:35:29.404 : extruder 0: temp sensor defect
16:35:29.408 : heated bed: working
16:35:29.410 : Error:Printer set into dry run mode until restart!
16:35:32.251 : N3376 M10522
16:35:32.300 : N3377 G1 X67.969 Y21.794 E232.858999
16:35:32.365 : N3378 G1 X216.012 Y21.791 E240.827884
16:35:32.391 : N3379 G1 X217.382 Y21.945 E240.902103
16:35:32.394 : N3380 G1 X218.657 Y22.391 E240.974785
16:35:32.398 : N3381 G1 X218.697 Y22.406 E240.977101
16:35:32.435 : N3382 G1 X219.855 Y23.134 E241.050689
16:35:32.484 : N3383 G1 X220.84 Y24.113 E241.1254101
16:35:32.529 : N3384 G1 X221.584 Y25.288 E241.200284
16:35:32.533 : N3385 G1 X222.037 Y26.57 E241.2734106
16:35:32.583 : N3386 G1 X222.054 Y26.614 E241.276108
16:35:40.172 : N3387 M10524
16:35:40.234 : N3388 M104 T0 S017
16:35:40.288 : N3389 M140 S084
16:35:40.311 : extruder 0: working
16:35:40.311 : heated bed: working
16:35:40.321 : Error:Printer set into dry run mode until restart!
16:35:40.321 : extruder 0: working
16:35:40.321 : heated bed: working
16:35:40.321 : N3390 G1 X0 Y0 F5000115
16:35:40.324 : N3391 M8439
16:35:40.328 : N3392 M10528
16:35:41.404 : N3393 M10529
16:35:48.455 : N3394 M10526
16:35:49.047 : N3395 M10527
16:35:50.142 : N3396 M10524
16:35:51.232 : N3397 M10525
16:35:52.328 : N3398 M10522
16:35:52.382 : N3399 G1 Z10.3 F20042
16:35:52.527 : N3400 G1 Z20.3 F20046
16:35:52.671 : N3401 G1 Z30.3 F20046
16:35:52.807 : N3402 G1 Z40.3 F20042
16:35:53.417 : N3403 M10519
16:35:54.513 : N3404 M10520
16:35:55.602 : N3405 M10521
16:35:56.691 : N3406 M10522
16:35:57.788 : N3407 M10523
16:35:58.876 : N3408 M10524
error3 (rotated 90??):
18:02:57.828 : N1922 G1 X215.235 Y253.156 E209.2486 F18002
18:02:57.857 : N1923 G1 X214.53 Y253.448 E209.289789
18:02:57.886 : N1924 G1 X213.918 Y253.918 E209.331397
18:02:57.914 : N1925 G1 X213.448 Y254.53 E209.372885
18:02:57.943 : N1926 G1 X213.156 Y255.235 E209.4139110
18:02:57.971 : N1927 G1 X213.056 Y256 E209.4554120
18:02:58.005 : N1928 G1 X213.156 Y256.76 E209.496684
18:02:58.033 : N1929 G1 X213.451 Y257.474 E209.538297
18:02:58.041 : extruder 0: temp sensor defect
18:02:58.045 : heated bed: working
18:02:58.049 : Error:Printer set into dry run mode until restart!
18:02:58.062 : N1930 G1 X213.917 Y258.081 E209.5794100
18:02:58.091 : N1931 G1 X214.53 Y258.551 E209.621105
18:02:58.119 : N1932 G1 X215.235 Y258.843 E209.662197
18:02:58.148 : N1933 G1 X216 Y258.944 E209.7036126
18:02:58.176 : N1934 G1 X216.76 Y258.843 E209.744992
18:02:58.209 : N1935 G1 X217.474 Y258.548 E209.7865110
18:02:58.238 : N1936 G1 X218.081 Y258.081 E209.8277106
18:02:58.266 : N1937 G1 X218.548 Y257.474 E209.8689111
18:02:58.295 : N1938 G1 X218.843 Y256.76 E209.910583
18:02:58.332 : N1939 G1 X218.944 Y256 E209.9518115
18:02:58.352 : N1940 G1 X218.843 Y255.235 E209.9933103
18:02:58.381 : N1941 G1 X218.551 Y254.53 E210.034480
18:02:58.406 : N1942 G1 X218.081 Y253.917 E210.07687
18:02:58.429 : N1943 G1 X217.474 Y253.451 E210.1172108
18:02:58.458 : N1944 G1 X216.76 Y253.156 E210.158780
18:02:58.483 : N1945 G1 X216 Y253.056 E210.270
18:02:58.507 : N1946 G0 X216 Y253.479 F4200103
18:02:58.532 : N1947 G1 X215.347 Y253.565 E210.2354 F18001
18:02:58.560 : N1948 G1 X214.736 Y253.817 E210.27194
18:02:58.585 : N1949 G1 X214.216 Y254.216 E210.3063102
18:02:58.610 : N1950 G1 X213.817 Y254.736 E210.341699
18:02:58.635 : N1951 G1 X213.565 Y255.347 E210.3772104
18:02:58.663 : N1952 M10524
18:02:58.688 : N1953 G1 X213.479 Y256 E210.4126123
18:02:58.712 : N1954 G1 X213.565 Y256.654 E210.448197
18:02:58.720 : N1955 G1 X213.816 Y257.26 E210.483489
18:02:58.737 : N1956 G1 X214.218 Y257.784 E210.51980
18:02:58.765 : N1957 G1 X214.736 Y258.182 E210.5541111
18:02:58.791 : N1958 G1 X215.35 Y258.436 E210.589987
18:02:58.815 : N1959 G1 X216 Y258.522 E210.6252119
18:02:58.841 : N1960 G1 X216.65 Y258.436 E210.660582
18:02:58.869 : N1961 G1 X217.26 Y258.183 E210.69698
18:02:58.893 : N1962 G1 X217.782 Y257.782 E210.7315105
18:02:58.918 : N1963 G1 X218.183 Y257.26 E210.766987
18:02:58.942 : N1964 G1 X218.436 Y256.65 E210.802493
18:02:58.975 : N1965 G1 X218.522 Y256 E210.8377112
18:02:59.003 : N1966 G1 X218.436 Y255.35 E210.873107
18:02:59.020 : N1967 G1 X218.182 Y254.736 E210.908896
18:02:59.045 : N1968 G1 X217.784 Y254.218 E210.94489
18:02:59.065 : N1969 G1 X217.26 Y253.816 E210.979595
18:02:59.086 : N1970 G1 X216.654 Y253.565 E211.014898
18:02:59.110 : N1971 G1 X216 Y253.479 E211.0503125
18:02:59.131 : N1972 G0 X222.209 Y256.012 F4200126
18:02:59.156 : N1973 G1 X222.054 Y257.382 E211.1245 F180011
18:02:59.176 : N1974 G1 X221.608 Y258.657 E211.197399
18:02:59.196 : N1975 G1 X221.593 Y258.697 E211.1996100
18:02:59.221 : N1976 G1 X220.865 Y259.855 E211.273296
18:02:59.241 : N1977 G1 X219.886 Y260.84 E211.347985
18:02:59.261 : N1978 G1 X218.711 Y261.584 E211.4228107
18:02:59.286 : N1979 G1 X217.429 Y262.037 E211.49684
18:02:59.307 : N1980 G1 X217.385 Y262.054 E211.4985109
18:02:59.329 : N1981 G1 X216.031 Y262.206 E211.5719110
18:02:59.352 : N1982 G1 X67.988 Y262.209 E219.540789
18:02:59.372 : N1983 G1 X66.617 Y262.054 E219.615110
18:02:59.392 : N1984 G1 X65.342 Y261.608 E219.687795
18:02:59.416 : N1985 G1 X65.302 Y261.593 E219.6990
18:02:59.437 : N1986 G1 X64.144 Y260.865 E219.763686
18:02:59.461 : N1987 G1 X63.159 Y259.886 E219.838395
18:02:59.482 : N1988 G1 X62.415 Y258.711 E219.913285
18:02:59.502 : N1989 G1 X61.96 Y257.423 E219.9867108
18:02:59.531 : N1990 G1 X61.945 Y257.385 E219.988988
18:02:59.667 : N1991 G1 X61.794 Y256.031 E220.062391
18:02:59.718 : N1992 G1 X61.791 Y27.988 E232.337398
18:02:59.761 : N1993 M10521
18:02:59.765 : N1994 G1 X61.945 Y26.617 E232.4116109
18:02:59.806 : N1995 G1 X62.391 Y25.342 E232.484399
18:02:59.813 : N1996 G1 X62.406 Y25.302 E232.4866106
18:02:59.855 : N1997 G1 X63.134 Y24.144 E232.560298
18:02:59.901 : N1998 G1 X64.113 Y23.159 E232.63585
18:02:59.946 : N1999 G1 X65.288 Y22.415 E232.7098110
18:02:59.953 : N2000 G1 X66.57 Y21.962 E232.78399
18:02:59.991 : N2001 G1 X66.614 Y21.945 E232.7856102
18:03:04.926 : N2002 M10523
18:03:04.972 : N2003 G1 X67.969 Y21.794 E232.858998
18:03:05.017 : N2004 G1 X216.012 Y21.791 E240.827893
18:03:05.032 : N2005 G1 X217.382 Y21.945 E240.902110
18:03:05.037 : N2006 G1 X218.657 Y22.391 E240.974789
18:03:05.061 : N2007 G1 X218.697 Y22.406 E240.977105
18:03:05.111 : N2008 G1 X219.855 Y23.134 E241.050689
18:03:05.156 : N2009 G1 X220.84 Y24.113 E241.1254101
18:03:05.200 : N2010 M10520
18:03:05.205 : N2011 G1 X221.584 Y25.288 E241.200290
18:03:05.250 : N2012 G1 X222.037 Y26.57 E241.2734102
18:03:05.257 : N2013 G1 X222.054 Y26.614 E241.27698
18:03:12.848 : N2014 M10516
18:03:12.893 : N2015 M10719
18:03:12.939 : N2016 M140 S080
18:03:12.969 : extruder 0: working
18:03:12.969 : heated bed: working
18:03:12.969 : Error:Printer set into dry run mode until restart!
18:03:12.969 : N2017 G1 E-1101
18:03:12.976 : N2018 M104 T0 S026
18:03:12.979 : N2019 G28 X0 F50050
18:03:12.983 : extruder 0: working
18:03:12.983 : heated bed: working
18:03:12.987 : Error:Printer set into dry run mode until restart!
18:03:12.987 : N2020 G28 Y0 F50057
18:03:12.992 : N2021 G1 Z250 F2000
18:03:24.649 : X:0.00 Y:26.61 Z:0.30 E:209.46
18:03:24.653 : N2022 T08
18:03:26.058 : X:0.00 Y:0.00 Z:0.30 E:209.46
18:03:26.058 : N2023 G9035
18:03:26.062 : N2024 G92 E0115
18:04:40.968 : N2025 T015
18:04:40.971 : N2026 M8441
18:04:40.975 : N2027 G9138
18:04:40.980 : N2028 M104 T0 S025
18:04:40.985 : N2029 M140 S092
18:04:40.987 : extruder 0: working
18:04:40.987 : heated bed: working
18:04:40.992 : Error:Printer set into dry run mode until restart!
18:04:40.992 : N2030 G1 X0 Y0 F5000123
18:04:40.996 : extruder 0: working
18:04:40.996 : heated bed: working
18:04:41.000 : Error:Printer set into dry run mode until restart!
18:04:41.004 : N2031 M8447
18:04:41.008 : N2032 M10520
18:04:41.288 : N2033 M10521
18:04:42.384 : N2034 M10518
18:04:43.473 : N2035 M10519
18:04:44.563 : N2036 M10516
18:04:45.658 : N2037 M10517
18:04:46.748 : N2038 M10530
18:04:47.844 : N2039 M10531
error4:
18:31:50.969 : N4516 G1 X61.791 Y27.988 E232.3373103
18:31:50.974 : N4517 G1 X61.945 Y26.617 E232.4116111
18:31:50.978 : N4518 G1 X62.391 Y25.342 E232.4843111
18:31:51.011 : N4519 G1 X62.406 Y25.302 E232.4866100
18:31:51.060 : N4520 G1 X63.134 Y24.144 E232.5602103
18:31:51.105 : N4521 G1 X64.113 Y23.159 E232.63594
18:31:51.150 : N4522 G1 X65.288 Y22.415 E232.7098103
18:31:51.155 : N4523 G1 X66.57 Y21.962 E232.78397
18:31:51.200 : N4524 G1 X66.614 Y21.945 E232.785698
18:31:52.580 : extruder 0: temp sensor defect
18:31:52.580 : heated bed: working
18:31:52.584 : Error:Printer set into dry run mode until restart!
18:31:56.131 : N4525 M10517
18:31:56.177 : N4526 G1 X67.969 Y21.794 E232.8589102
18:31:56.221 : N4527 M10519
18:31:56.298 : N4528 G1 X216.012 Y21.791 E240.827880
18:31:56.303 : N4529 G1 X217.382 Y21.945 E240.90299
18:31:56.308 : N4530 G1 X218.657 Y22.391 E240.974795
18:31:56.311 : N4531 G1 X218.697 Y22.406 E240.977111
18:31:56.315 : N4532 G1 X219.855 Y23.134 E241.050683
18:31:56.361 : N4533 G1 X220.84 Y24.113 E241.1254111
18:31:56.406 : N4534 G1 X221.584 Y25.288 E241.200294
18:31:56.410 : N4535 G1 X222.037 Y26.57 E241.273496
18:31:56.455 : N4536 G1 X222.054 Y26.614 E241.276102
18:32:04.053 : N4537 M10518
18:32:04.098 : N4538 G1 X222.206 Y27.969 E241.349387
18:32:04.144 : N4539 G1 X222.209 Y256.012 E253.624498
18:32:04.188 : N4540 G0 X222.628 Y256.035 F4200116
18:32:04.192 : N4541 G1 X222.465 Y257.476 E253.7025 F180013
18:32:04.196 : N4542 G1 X222.001 Y258.802 E253.7781110
18:32:04.237 : N4543 G1 X221.969 Y258.887 E253.78383
18:32:04.283 : N4544 G1 X221.195 Y260.117 E253.8612101
18:32:04.328 : N4545 G1 X220.15 Y261.169 E253.941101
18:32:04.332 : N4546 G1 X218.895 Y261.964 E254.02180
18:32:04.377 : N4547 G1 X217.573 Y262.43 E254.096492
18:32:09.308 : N4548 M10526
18:32:09.354 : N4549 G1 X217.486 Y262.464 E254.1015102
18:32:09.399 : N4550 G1 X216.054 Y262.625 E254.17989
18:32:09.444 : N4551 G1 X67.965 Y262.628 E262.150387
18:32:09.451 : N4552 G1 X66.523 Y262.465 E262.228590
18:32:09.456 : N4553 G1 X65.197 Y262.001 E262.304111
18:32:09.493 : N4554 G1 X65.112 Y261.969 E262.309108
18:32:09.539 : N4555 G1 X63.882 Y261.195 E262.387284
18:32:09.583 : N4556 G1 X62.83 Y260.15 E262.467108
18:32:09.587 : N4557 G1 X62.035 Y258.895 E262.547104
18:32:09.632 : N4558 G1 X61.565 Y257.562 E262.623111
18:32:17.238 : N4559 M10526
18:32:17.259 : N4560 M10718
18:32:17.309 : N4561 M140 S083
18:32:17.369 : extruder 0: working
18:32:17.369 : heated bed: working
18:32:17.369 : Error:Printer set into dry run mode until restart!
18:32:17.371 : N4562 G1 E-1100
18:32:17.374 : N4563 M104 T0 S021
18:32:17.377 : N4564 G9134
18:32:17.382 : extruder 0: temp sensor defect
18:32:17.382 : heated bed: working
18:32:17.389 : Error:Printer set into dry run mode until restart!
18:32:17.390 : N4565 G1 Z10 F20053
18:32:17.394 : N4566 G28 X0 F50057
18:32:17.400 : N4567 G28 Y0 F50057
18:32:17.406 : N4568 T05
18:32:28.134 : X:0.00 Y:257.56 Z:10.30 E:232.71
18:32:28.134 : N4569 G9046
18:32:35.323 : X:0.00 Y:0.00 Z:10.30 E:232.71
18:32:35.323 : N4570 G92 E0113
18:32:35.327 : N4571 T013
18:32:35.331 : N4572 M8443
18:32:35.335 : N4573 G9136
18:32:35.339 : N4574 M104 T0 S019
18:32:35.344 : N4575 M140 S086
18:32:35.347 : extruder 0: working
18:32:35.347 : heated bed: working
18:32:35.351 : Error:Printer set into dry run mode until restart!
18:32:35.352 : N4576 G1 X0 Y0 F5000122
18:32:35.355 : extruder 0: working
18:32:35.355 : heated bed: working
18:32:35.360 : Error:Printer set into dry run mode until restart!
18:32:35.363 : N4577 M8446
18:32:35.368 : N4578 M105*25
I'm really out of ideas, maybe someone else already know this problem, or has the same issue as i do.
(sorry for the long post)
