Ok, sorry so i missunderstood this. Yes this were the dmesg.
So the print stopping was on Nov 21 at 19:14.
So I took the Server logs from starting the print:
2017-11-21 16:54:49: start printjob pistand on printer
01_Proto
2017-11-21 16:54:49: Added timelapse 20171121T165449_pistand
2017-11-21 16:55:49: Reading configuration file ...
Input file:
/var/lib/Repetier-Server/printer/01_Dildoser/models/00000037_pistand.layer
Rendering shadows ...6.14843 seconds.
Rendering gcode ...64.4306 seconds.
Number of end triangles: 30096
Number of normal triangles: 2171416
Rendering background ...
Time for raytracing: 15.2028 seconds.
images stored.
Computation time: 88.3188 seconds
2017-11-21 16:55:49: LUA job
rendering.render#{"id":13,"image":"/var/lib/Repetier-Server/printer/01_Dildoser/jobs/00000013_pistand_l.png","layer":"/var/lib/Repetier-Server/printer/01_Dildoser/jobs/00000013_pistand.layer","list":"jobs","slug":"01_Dildoser"}
2017-11-21 16:57:18: Reading configuration file ...
Input file:
Rendering shadows ...6.17066 seconds.
Rendering gcode ...65.5643 seconds.
Time for raytracing: 15.1747 seconds.
images stored.
Computation time: 89.3802 seconds
2017-11-21 17:07:34:
Video:/var/lib/Repetier-Server/printer/01_Dildoser/timelapse/20171121T153334_300x300/video.mp4
2017-11-21 17:08:34: Closing websocket for missing ping
2017-11-21 19:14:32: error: Reading serial conection failed:
End of file. Closing connection.
2017-11-21 19:14:32: Connection closed: 01_Proto
2017-11-21 19:14:33: /usr/bin/ffmpeg -loglevel error -f concat
-i input.txt -i /var/lib/Repetier-Server/database/watermark.png -c:v libx264
-filter_complex [0:v][1:v]overlay=10:10 -threads 1 -r 30 -pix_fmt yuv420p
-profile:v baseline -level 3.0 -movflags +faststart -b:v 1000k -y video.mp4
2017-11-21 19:14:33: cwd =
/var/lib/Repetier-Server/printer/01_Dildoser/timelapse/20171121T165449_pistand
2017-11-21 19:14:35: Connection started:01_Proto
2017-11-21 19:14:35: Reset printer 01_Proto
2017-11-21 19:15:51:
2017-11-21 19:15:54: error: Reading serial conection failed:
2017-11-21 19:15:54: Connection closed: 01_Proto
2017-11-21 19:15:57: Connection started:01_Proto
2017-11-21 19:15:57: Reset printer 01_Proto
2017-11-21 19:20:32: Activating access point
And also the Syslog:
Nov 21 18:59:34 RepetierServer MJPG-streamer [19141]:
serving client: 127.0.0.1
Nov 21 19:00:12 RepetierServer MJPG-streamer [19141]:
Nov 21 19:00:22 RepetierServer MJPG-streamer [19141]:
Nov 21 19:00:34 RepetierServer wpa_supplicant[713]: wlan0:
Failed to initiate sched sca
n
Nov 21 19:00:59 RepetierServer MJPG-streamer [19141]:
Nov 21 19:01:09 RepetierServer MJPG-streamer [19141]:
Nov 21 19:01:37 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:01:49 RepetierServer MJPG-streamer [19141]:
Nov 21 19:02:26 RepetierServer MJPG-streamer [19141]:
Nov 21 19:02:36 RepetierServer MJPG-streamer [19141]:
Nov 21 19:02:40 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:03:14 RepetierServer MJPG-streamer [19141]:
Nov 21 19:03:24 RepetierServer MJPG-streamer [19141]:
Nov 21 19:03:43 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:04:03 RepetierServer MJPG-streamer [19141]:
Nov 21 19:04:40 RepetierServer MJPG-streamer [19141]:
Nov 21 19:04:46 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:04:51 RepetierServer MJPG-streamer [19141]:
Nov 21 19:05:28 RepetierServer MJPG-streamer [19141]:
Nov 21 19:05:38 RepetierServer MJPG-streamer [19141]:
Nov 21 19:05:49 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:06:18 RepetierServer MJPG-streamer [19141]:
Nov 21 19:06:52 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:06:54 RepetierServer MJPG-streamer [19141]:
Nov 21 19:07:04 RepetierServer MJPG-streamer [19141]:
Nov 21 19:07:42 RepetierServer MJPG-streamer [19141]:
Nov 21 19:07:53 RepetierServer MJPG-streamer [19141]:
Nov 21 19:07:55 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:08:31 RepetierServer MJPG-streamer [19141]:
Nov 21 19:08:58 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:09:09 RepetierServer MJPG-streamer [19141]:
Nov 21 19:09:19 RepetierServer MJPG-streamer [19141]:
Nov 21 19:09:56 RepetierServer MJPG-streamer [19141]:
Nov 21 19:10:01 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:10:06 RepetierServer MJPG-streamer [19141]:
Nov 21 19:10:46 RepetierServer MJPG-streamer [19141]:
Nov 21 19:11:04 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:11:23 RepetierServer MJPG-streamer [19141]:
Nov 21 19:11:33 RepetierServer MJPG-streamer [19141]:
Nov 21 19:12:07 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:12:10 RepetierServer MJPG-streamer [19141]:
Nov 21 19:12:21 RepetierServer MJPG-streamer [19141]:
Nov 21 19:13:00 RepetierServer MJPG-streamer [19141]:
Nov 21 19:13:10 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:13:37 RepetierServer MJPG-streamer [19141]:
Nov 21 19:13:48 RepetierServer MJPG-streamer [19141]:
Nov 21 19:14:13 RepetierServer wpa_supplicant[713]: wlan0:
n
Nov 21 19:14:25 RepetierServer MJPG-streamer [19141]:
Nov 21 19:14:32 RepetierServer kernel: [31621.570029]
NYET/NAK/ACK/other in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570055]
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570078]
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570103] NYET/NAK/ACK/other
in non-error c
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570120]
ase, 0x00000002
Nov 21 19:14:32 RepetierServer kernel: [31621.570138]
ase, 0x00000002
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: arp
if_readrawpacket: Network is down
Nov 21 19:14:32 RepetierServer kernel: [31621.614714] usb
usb1-port1: disabled by hub (
EMI?), re-enabling...
Nov 21 19:14:32 RepetierServer kernel: [31621.614732] usb
1-1: USB disconnect, device n
umber 12
Nov 21 19:14:32 RepetierServer kernel: [31621.614738] usb
1-1.1: USB disconnect, device
number 13
Nov 21 19:14:32 RepetierServer kernel: [31621.615067] smsc95xx
1-1.1:1.0 eth0: unregist
er 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0
Ethernet
Nov 21 19:14:32 RepetierServer kernel: [31621.615252]
smsc95xx 1-1.1:1.0 eth0: hardware
isn't capable of
remote wakeup
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: carrier
lost
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Interface
eth0.IPv6 no longer relevan
t for mDNS.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Leaving
mDNS multicast group on inter
face eth0.IPv6 with address fe80::96c5:4333:2403:f1ca.
eth0.IPv4 no longer relevan
t for mDNS.
face eth0.IPv4 with address 10.10.143.11.
Withdrawing address record for fe80::
96c5:4333:2403:f1ca on eth0.
Withdrawing address record for 10.10.
143.11 on eth0.
Nov 21 19:14:32 RepetierServer avahi-daemon[440]: Withdrawing
workstation service for e
th0.
Nov 21 19:14:32 RepetierServer NetworkManager[442]:
<info> devices removed (path: /sys/
devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0,
iface: eth0)
<info> get unmanaged devices count:
0
Nov 21 19:14:32 RepetierServer kernel: [31621.656879] usb
1-1.3: USB disconnect, device
number 14
Nov 21 19:14:32 RepetierServer kernel: [31621.657051]
ftdi_sio ttyUSB0: error from flow
control urb
Nov 21 19:14:32 RepetierServer kernel: [31621.658563]
ftdi_sio ttyUSB0: FTDI USB Serial
Device converter now
disconnected from ttyUSB0
Nov 21 19:14:32 RepetierServer kernel: [31621.658593]
ftdi_sio 1-1.3:1.0: device discon
nected
Nov 21 19:14:32 RepetierServer kernel: [31621.660298] usb
1-1.5: USB disconnect, device
number 15
Nov 21 19:14:32 RepetierServer kernel: [31621.764823]
WARNING: CPU: 3 PID: 20928 at fs/
sysfs/group.c:237 sysfs_remove_group+0xa0/0xa4
Nov 21 19:14:32 RepetierServer kernel: [31621.764826] sysfs
group 'power' not found for
kobject 'event1'
Nov 21 19:14:32 RepetierServer kernel: [31621.764828]
Modules linked in: ftdi_sio usbse
rial bnep bluetooth brcmfmac uvcvideo brcmutil cfg80211
videobuf2_vmalloc snd_usb_audio
fb_ili9486(C)
videobuf2_memops snd_hwdep fbtft(C) videobuf2_v4l2 snd_usbmidi_lib rfkil
l syscopyarea videobuf2_core evdev sysfillrect snd_rawmidi
joydev videodev sysimgblt sn
d_seq_device media fb_sys_fops ads7846 hwmon snd_bcm2835
snd_pcm snd_timer snd i2c_bcm2
835 spi_bcm2835 bcm2835_gpiomem uio_pdrv_genirq uio fixed
i2c_dev fuse ipv6
Nov 21 19:14:32 RepetierServer kernel: [31621.764943] CPU: 3
PID: 20928 Comm: mjpg_stre
amer Tainted: G
WC 4.9.35-v7+ #1014
Nov 21 19:14:32 RepetierServer kernel: [31621.764946]
Hardware name: BCM2835
Nov 21 19:14:32 RepetierServer kernel: [31621.764963]
[<8010fb3c>] (unwind_backtrace) f
rom [<8010c058>] (show_stack+0x20/0x24)
Nov 21 19:14:32 RepetierServer kernel: [31621.764973]
[<8010c058>] (show_stack) from [<
80455880>] (dump_stack+0xd4/0x118)
Nov 21 19:14:32 RepetierServer kernel: [31621.764982]
[<80455880>] (dump_stack) from [<
8011d344>] (__warn+0xf8/0x110)
Nov 21 19:14:32 RepetierServer kernel: [31621.764989]
[<8011d344>] (__warn) from [<8011
d3a4>] (warn_slowpath_fmt+0x48/0x50)
Nov 21 19:14:32 RepetierServer kernel: [31621.764995]
[<8011d3a4>] (warn_slowpath_fmt)
from [<802edb84>] (sysfs_remove_group+0xa0/0xa4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765006]
[<802edb84>] (sysfs_remove_group)
from
[<805022e8>] (dpm_sysfs_remove+0x5c/0x60)
Nov 21 19:14:32 RepetierServer kernel: [31621.765017]
[<805022e8>] (dpm_sysfs_remove) f
rom [<804f6c44>] (device_del+0x48/0x22c)
Nov 21 19:14:32 RepetierServer kernel: [31621.765030]
[<804f6c44>] (device_del) from [<
7f1c01cc>] (evdev_disconnect+0x28/0x50 [evdev])
Nov 21 19:14:32 RepetierServer kernel: [31621.765044]
[<7f1c01cc>] (evdev_disconnect [e
vdev]) from [<805989a8>]
(__input_unregister_device+0xc0/0x160)
Nov 21 19:14:32 RepetierServer kernel: [31621.765053]
[<805989a8>] (__input_unregister_
device) from [<805992d0>]
(input_unregister_device+0x58/0x80)
Nov 21 19:14:32 RepetierServer kernel: [31621.765079]
[<805992d0>] (input_unregister_de
vice) from [<7f3e16a0>] (uvc_status_cleanup+0x40/0x44
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.765114]
[uvcvideo]) from [<7f3d731c>] (uvc_delete+0x1c/0x14c
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.765147]
[<7f3d731c>] (uvc_delete [uvcvide
o]) from [<7f3d7584>] (uvc_release+0x4c/0x50
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.765230]
[<7f3d7584>] (uvc_release [uvcvid
eo]) from [<7f16880c>] (v4l2_device_release+0xd8/0xfc
[videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.765289]
[videodev]) from
[<804f6398>] (device_release+0x3c/0xa0)
Nov 21 19:14:32 RepetierServer kernel: [31621.765299]
[<804f6398>] (device_release) fro
m [<80457abc>] (kobject_release+0x50/0x84)
Nov 21 19:14:32 RepetierServer kernel: [31621.765308]
[<80457abc>] (kobject_release) fr
om [<80457b44>] (kobject_put+0x54/0x80)
Nov 21 19:14:32 RepetierServer kernel: [31621.765315]
[<80457b44>] (kobject_put) from [
<804f6744>] (put_device+0x24/0x28)
Nov 21 19:14:32 RepetierServer kernel: [31621.765381]
[<804f6744>] (put_device) from [<
7f168518>] (v4l2_release+0x60/0x84 [videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.765440]
[<7f168518>] (v4l2_release [video
dev]) from [<802720f0>] (__fput+0x9c/0x1e8)
Nov 21 19:14:32 RepetierServer kernel: [31621.765449]
[<802720f0>] (__fput) from [<8027
22ac>] (____fput+0x18/0x1c)
Nov 21 19:14:32 RepetierServer kernel: [31621.765457]
[<802722ac>] (____fput) from [<80
13ab9c>] (task_work_run+0xcc/0xfc)
Nov 21 19:14:32 RepetierServer kernel: [31621.765465]
[<8013ab9c>] (task_work_run) from
[<80121354>]
(do_exit+0x370/0xaec)
Nov 21 19:14:32 RepetierServer kernel: [31621.765472]
[<80121354>] (do_exit) from [<801
21b68>] (do_group_exit+0x4c/0xe4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765479]
[<80121b68>] (do_group_exit) from
[<8012cc34>]
(get_signal+0x370/0x6d4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765489]
[<8012cc34>] (get_signal) from [<
8010b2cc>] (do_signal+0x74/0x3e4)
Nov 21 19:14:32 RepetierServer kernel: [31621.765498]
[<8010b2cc>] (do_signal) from [<8
010b824>] (do_work_pending+0xb8/0xd0)
Nov 21 19:14:32 RepetierServer kernel: [31621.765506]
[<8010b824>] (do_work_pending) fr
om [<801080e8>] (slow_work_pending+0xc/0x20)
Nov 21 19:14:32 RepetierServer kernel: [31621.765510] ---[
end trace ff3c27833be5c301 ]
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: deleting
:f1ca
route to 10.10.140.0/22
default route via 10.10.140.
1
Nov 21 19:14:32 RepetierServer kernel: [31621.834824]
------------[ cut here ]---------
Nov 21 19:14:32 RepetierServer kernel: [31621.834843]
Nov 21 19:14:32 RepetierServer kernel: [31621.834846] sysfs
kobject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.834848]
fb_ili9486(C)
i2c_dev fuse ipv6
Nov 21 19:14:32 RepetierServer kernel: [31621.834938] CPU: 3
amer Tainted: G
WC 4.9.35-v7+ #1014
Nov 21 19:14:32 RepetierServer kernel: [31621.834940]
Nov 21 19:14:32 RepetierServer kernel: [31621.834959]
Nov 21 19:14:32 RepetierServer kernel: [31621.834969]
Nov 21 19:14:32 RepetierServer kernel: [31621.834978]
Nov 21 19:14:32 RepetierServer kernel: [31621.834985]
Nov 21 19:14:32 RepetierServer kernel: [31621.834991]
Nov 21 19:14:32 RepetierServer kernel: [31621.835002]
from
Nov 21 19:14:32 RepetierServer kernel: [31621.835012]
Nov 21 19:14:32 RepetierServer kernel: [31621.835022]
80598a2c>] (__input_unregister_device+0x144/0x160)
Nov 21 19:14:32 RepetierServer kernel: [31621.835031]
[<80598a2c>] (__input_unregister_
Nov 21 19:14:32 RepetierServer kernel: [31621.835058]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835093]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835127]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835208]
[videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.835266]
[videodev]) from
Nov 21 19:14:32 RepetierServer kernel: [31621.835276]
Nov 21 19:14:32 RepetierServer kernel: [31621.835285]
Nov 21 19:14:32 RepetierServer kernel: [31621.835292]
Nov 21 19:14:32 RepetierServer kernel: [31621.835347]
Nov 21 19:14:32 RepetierServer kernel: [31621.835404]
Nov 21 19:14:32 RepetierServer kernel: [31621.835412]
Nov 21 19:14:32 RepetierServer kernel: [31621.835420]
Nov 21 19:14:32 RepetierServer kernel: [31621.835429]
[<80121354>]
Nov 21 19:14:32 RepetierServer kernel: [31621.835436]
Nov 21 19:14:32 RepetierServer kernel: [31621.835443]
[<8012cc34>]
Nov 21 19:14:32 RepetierServer kernel: [31621.835452]
Nov 21 19:14:32 RepetierServer kernel: [31621.835460]
Nov 21 19:14:32 RepetierServer kernel: [31621.835468]
Nov 21 19:14:32 RepetierServer kernel: [31621.835472] ---[
end trace ff3c27833be5c302 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.835492]
Nov 21 19:14:32 RepetierServer kernel: [31621.835498]
Nov 21 19:14:32 RepetierServer kernel: [31621.835501] sysfs
group 'id' not found for ko
bject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.835502]
fb_ili9486(C)
i2c_dev fuse ipv6
Nov 21 19:14:32 RepetierServer kernel: [31621.835576] CPU: 3
amer Tainted: G
WC 4.9.35-v7+ #1014
Nov 21 19:14:32 RepetierServer kernel: [31621.835578]
Nov 21 19:14:32 RepetierServer kernel: [31621.835586]
Nov 21 19:14:32 RepetierServer kernel: [31621.835593]
Nov 21 19:14:32 RepetierServer kernel: [31621.835600]
Nov 21 19:14:32 RepetierServer kernel: [31621.835605]
Nov 21 19:14:32 RepetierServer kernel: [31621.835612]
Nov 21 19:14:32 RepetierServer kernel: [31621.835618]
from
[<802edbbc>] (sysfs_remove_groups+0x34/0x44)
Nov 21 19:14:32 RepetierServer kernel: [31621.835625]
) from [<804f62c0>] (device_remove_attrs+0x60/0x7c)
Nov 21 19:14:32 RepetierServer kernel: [31621.835632]
) from [<804f6d10>] (device_del+0x114/0x22c)
Nov 21 19:14:32 RepetierServer kernel: [31621.835640]
[<804f6d10>] (device_del) from [<
Nov 21 19:14:32 RepetierServer kernel: [31621.835648]
Nov 21 19:14:32 RepetierServer kernel: [31621.835669]
vice) from [<7f3e16a0>] (uvc_status_cleanup+0x40/0x44 [uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835703]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835736]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.835803]
[videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.835859]
[videodev]) from
Nov 21 19:14:32 RepetierServer kernel: [31621.835867]
Nov 21 19:14:32 RepetierServer kernel: [31621.835875]
Nov 21 19:14:32 RepetierServer kernel: [31621.835882]
Nov 21 19:14:32 RepetierServer kernel: [31621.835937]
Nov 21 19:14:32 RepetierServer kernel: [31621.835993]
Nov 21 19:14:32 RepetierServer kernel: [31621.836001]
Nov 21 19:14:32 RepetierServer kernel: [31621.836007]
Nov 21 19:14:32 RepetierServer kernel: [31621.836014]
[<80121354>]
Nov 21 19:14:32 RepetierServer kernel: [31621.836020]
Nov 21 19:14:32 RepetierServer kernel: [31621.836026]
[<8012cc34>]
Nov 21 19:14:32 RepetierServer kernel: [31621.836033]
Nov 21 19:14:32 RepetierServer kernel: [31621.836042]
Nov 21 19:14:32 RepetierServer kernel: [31621.836049]
Nov 21 19:14:32 RepetierServer kernel: [31621.836052] ---[
end trace ff3c27833be5c303 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.836055]
Nov 21 19:14:32 RepetierServer kernel: [31621.836060]
Nov 21 19:14:32 RepetierServer kernel: [31621.836063] sysfs
group 'capabilities' not fo
und for kobject 'input3'
Nov 21 19:14:32 RepetierServer kernel: [31621.836064]
fb_ili9486(C)
i2c_dev fuse ipv6
Nov 21 19:14:32 RepetierServer kernel: [31621.836135] CPU: 3
amer Tainted: G
WC 4.9.35-v7+ #1014
Nov 21 19:14:32 RepetierServer kernel: [31621.836137]
Nov 21 19:14:32 RepetierServer kernel: [31621.836144]
Nov 21 19:14:32 RepetierServer kernel: [31621.836151]
Nov 21 19:14:32 RepetierServer kernel: [31621.836158]
Nov 21 19:14:32 RepetierServer kernel: [31621.836163] [<8011d344>]
Nov 21 19:14:32 RepetierServer kernel: [31621.836170]
Nov 21 19:14:32 RepetierServer kernel: [31621.836176]
from
Nov 21 19:14:32 RepetierServer kernel: [31621.836182]
Nov 21 19:14:32 RepetierServer kernel: [31621.836189]
Nov 21 19:14:32 RepetierServer kernel: [31621.836196]
Nov 21 19:14:32 RepetierServer kernel: [31621.836204]
Nov 21 19:14:32 RepetierServer kernel: [31621.836225]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.836259]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.836292]
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.836359]
[videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.836415]
[videodev]) from
Nov 21 19:14:32 RepetierServer kernel: [31621.836423]
Nov 21 19:14:32 RepetierServer kernel: [31621.836431]
Nov 21 19:14:32 RepetierServer kernel: [31621.836438]
Nov 21 19:14:32 RepetierServer kernel: [31621.836493]
Nov 21 19:14:32 RepetierServer kernel: [31621.836549]
Nov 21 19:14:32 RepetierServer kernel: [31621.836556]
Nov 21 19:14:32 RepetierServer kernel: [31621.836563]
Nov 21 19:14:32 RepetierServer kernel: [31621.836570]
[<80121354>]
Nov 21 19:14:32 RepetierServer kernel: [31621.836576]
Nov 21 19:14:32 RepetierServer kernel: [31621.836582]
[<8012cc34>]
Nov 21 19:14:32 RepetierServer kernel: [31621.836589]
Nov 21 19:14:32 RepetierServer kernel: [31621.836597]
Nov 21 19:14:32 RepetierServer kernel: [31621.836605]
Nov 21 19:14:32 RepetierServer kernel: [31621.836608] ---[
end trace ff3c27833be5c304 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.836710]
Nov 21 19:14:32 RepetierServer kernel: [31621.836716]
Nov 21 19:14:32 RepetierServer kernel: [31621.836719] sysfs
kobject 'media0'
Nov 21 19:14:32 RepetierServer kernel: [31621.836720]
fb_ili9486(C)
i2c_dev fuse ipv6
Nov 21 19:14:32 RepetierServer kernel: [31621.836792] CPU: 3
amer Tainted: G
WC 4.9.35-v7+ #1014
Nov 21 19:14:32 RepetierServer kernel: [31621.836794]
Nov 21 19:14:32 RepetierServer kernel: [31621.836801]
Nov 21 19:14:32 RepetierServer kernel: [31621.836808]
Nov 21 19:14:32 RepetierServer kernel: [31621.836815]
Nov 21 19:14:32 RepetierServer kernel: [31621.836821]
Nov 21 19:14:32 RepetierServer kernel: [31621.836828]
Nov 21 19:14:32 RepetierServer kernel: [31621.836836] [<802edb84>]
from
Nov 21 19:14:32 RepetierServer kernel: [31621.836844]
Nov 21 19:14:32 RepetierServer kernel: [31621.836865]
7f152868>] (media_devnode_unregister+0x44/0x58 [media])
Nov 21 19:14:32 RepetierServer kernel: [31621.836894]
[<7f152868>] (media_devnode_unreg
ister [media]) from [<7f1521b0>]
(media_device_unregister+0x128/0x140 [media])
Nov 21 19:14:32 RepetierServer kernel: [31621.836925]
[<7f1521b0>] (media_device_unregi
ster [media]) from [<7f3d736c>] (uvc_delete+0x6c/0x14c
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.836958]
[<7f3d736c>] (uvc_delete [uvcvide
[uvcvideo])
Nov 21 19:14:32 RepetierServer kernel: [31621.837025]
[videodev])
Nov 21 19:14:32 RepetierServer kernel: [31621.837081]
[videodev]) from
Nov 21 19:14:32 RepetierServer kernel: [31621.837089]
Nov 21 19:14:32 RepetierServer kernel: [31621.837098]
Nov 21 19:14:32 RepetierServer kernel: [31621.837105]
Nov 21 19:14:32 RepetierServer kernel: [31621.837160]
Nov 21 19:14:32 RepetierServer kernel: [31621.837216]
Nov 21 19:14:32 RepetierServer kernel: [31621.837224]
Nov 21 19:14:32 RepetierServer kernel: [31621.837231]
Nov 21 19:14:32 RepetierServer kernel: [31621.837238]
[<80121354>]
Nov 21 19:14:32 RepetierServer kernel: [31621.837244]
Nov 21 19:14:32 RepetierServer kernel: [31621.837251]
[<8012cc34>]
Nov 21 19:14:32 RepetierServer kernel: [31621.837258]
Nov 21 19:14:32 RepetierServer kernel: [31621.837267]
Nov 21 19:14:32 RepetierServer kernel: [31621.837275]
Nov 21 19:14:32 RepetierServer kernel: [31621.837278] ---[
end trace ff3c27833be5c305 ]
Nov 21 19:14:32 RepetierServer kernel: [31621.854746] Indeed
it is in host mode hprt0 =
00001501
Nov 21 19:14:32 RepetierServer dhcpcd[840]: eth0: removing
interface
Nov 21 19:14:32 RepetierServer kernel: [31622.054688] usb
1-1: new high-speed USB devic
e number 16 using dwc_otg
Nov 21 19:14:32 RepetierServer kernel: [31622.054805] Indeed
00001101
Nov 21 19:14:32 RepetierServer kernel: [31622.284789] usb
1-1: New USB device found, id
Vendor=0424, idProduct=9514
Nov 21 19:14:32 RepetierServer kernel: [31622.284798] usb
1-1: New USB device strings:
Mfr=0, Product=0, SerialNumber=0
Nov 21 19:14:32 RepetierServer kernel: [31622.293526] hub
1-1:1.0: USB hub found
Nov 21 19:14:32 RepetierServer kernel: [31622.293610] hub
1-1:1.0: 5 ports detected
Nov 21 19:14:33 RepetierServer kernel: [31622.604684] usb
1-1.1: new high-speed USB dev
ice number 17 using dwc_otg
Nov 21 19:14:33 RepetierServer kernel: [31622.734952] usb
1-1.1: New USB device found,
idVendor=0424, idProduct=ec00
Nov 21 19:14:33 RepetierServer kernel: [31622.734962] usb
1-1.1: New USB device strings
: Mfr=0, Product=0, SerialNumber=0
Nov 21 19:14:33 RepetierServer kernel: [31622.742818]
smsc95xx v1.0.5
Nov 21 19:14:33 RepetierServer kernel: [31622.826863]
smsc95xx 1-1.1:1.0 eth0: register
'smsc95xx' at
usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:69:7a:69
Nov 21 19:14:33 RepetierServer kernel: [31622.924689] usb
1-1.3: new full-speed USB dev
ice number 18 using dwc_otg
Nov 21 19:14:33 RepetierServer kernel: [31623.083489] usb
1-1.3: New USB device found,
idVendor=0403, idProduct=6001
Nov 21 19:14:33 RepetierServer kernel: [31623.083499] usb
1-1.3: New USB device strings
: Mfr=1, Product=2, SerialNumber=3
Nov 21 19:14:33 RepetierServer kernel: [31623.083503] usb
1-1.3: Product: FT232R USB UA
RT
Nov 21 19:14:33 RepetierServer kernel: [31623.083507] usb
1-1.3: Manufacturer: FTDI
Nov 21 19:14:33 RepetierServer kernel: [31623.083511] usb
1-1.3: SerialNumber: A50653JG
Nov 21 19:14:33 RepetierServer kernel: [31623.091660]
ftdi_sio 1-1.3:1.0: FTDI USB Seri
al Device converter detected
Nov 21 19:14:33 RepetierServer kernel: [31623.091771] usb
1-1.3: Detected FT232RL
Nov 21 19:14:33 RepetierServer kernel: [31623.092579] usb
1-1.3: FTDI USB Serial Device
converter now
attached to ttyUSB0
Nov 21 19:14:33 RepetierServer kernel: [31623.394679] usb
1-1.5: new high-speed USB dev
ice number 19 using dwc_otg
Nov 21 19:14:34 RepetierServer kernel: [31623.585263] usb
1-1.5: New USB device found,
idVendor=1908, idProduct=2310
Nov 21 19:14:34 RepetierServer kernel: [31623.585272] usb
1-1.5: New USB device strings
Nov 21 19:14:34 RepetierServer kernel: [31623.585276] usb
1-1.5: Product: USB2.0 PC CAM
ERA
Nov 21 19:14:34 RepetierServer kernel: [31623.585280] usb
1-1.5: Manufacturer: Generic
Nov 21 19:14:34 RepetierServer kernel: [31623.585284] usb
1-1.5: SerialNumber: 20100331
010203
Nov 21 19:14:34 RepetierServer kernel: [31623.585977]
uvcvideo: Found UVC 1.00 device U
SB2.0 PC CAMERA (1908:2310)
Nov 21 19:14:34 RepetierServer kernel: [31623.586479]
uvcvideo 1-1.5:1.0: Entity type f
or entity Processing 2 was not initialized!
Nov 21 19:14:34 RepetierServer kernel: [31623.586488]
or entity Camera 1 was not initialized!
Nov 21 19:14:34 RepetierServer kernel: [31623.586789] input:
USB2.0 PC CAMERA as /devic
es/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input4
Nov 21 19:14:34 RepetierServer systemd[1]: Stopping
mjpg_streamer for picam...
Nov 21 19:14:34 RepetierServer systemd[1]: Starting
Nov 21 19:14:34 RepetierServer systemd[1]: Started
Nov 21 19:14:34 RepetierServer startAllCams[26656]: Webcam
does not support MJPG - usin
g slower YUYV instead!
Nov 21 19:14:34 RepetierServer startAllCams[26656]: Best
resolution: 640 x 480 at 30
/usr/local/bin/mjpg_streamer -i "/u
sr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps
30 -q 85 -r 640x480 -y " -
o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080
-w /usr/local/share/mjpg-streame
r/www" -b
Nov 21 19:14:34 RepetierServer MJPG-streamer [26677]:
starting application
Nov 21 19:14:34 RepetierServer MJPG-streamer [26677]: enabling
daemon mode
Nov 21 19:14:34 RepetierServer dhcpcd[840]: eth0: adding
1ca
Nov 21 19:14:34 RepetierServer NetworkManager[442]:
<info> (eth0): carrier is OFF
Nov 21 19:14:34 RepetierServer startAllCams[26656]: enabling
daemon modeforked to backg
round (26680)
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: MJPG
Streamer Version.: 2.0
<info> (eth0): new Ethernet device
(driver: 'smsc95xx' ifindex: 6)
<info> (eth0): exported as /org/fre
edesktop/NetworkManager/Devices/5
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Using
V4L2 device.: /dev/video0
Desired Resolution: 640 x 480
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: Frames
Per Second.: 30
Format............: YUYV
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: JPEG
Quality......: 85
TV-Norm...........: DEFAULT
<info> (eth0): device state change:
unmanaged ->
unavailable (reason 'managed') [10 20 2]
www-folder-path...: /usr/local/sh
are/mjpg-streamer/www/
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: HTTP
TCP port.....: 8080
username:password.: disabled
commands..........: enabled
starting input plugin /usr/local/
Nov 21 19:14:34 RepetierServer MJPG-streamer [26680]: starting
output plugin: /usr/loca
l/lib/mjpg-streamer/output_http.so (ID: 00)
<info> (eth0): preparing device
<info> (eth0): created default wire
d connection 'Wired connection 1'
<info> devices added (path: /sys/de
iface: eth0)
<info> locking wired connection set
ting
1
unavailable ->
unmanaged (reason 'unmanaged') [20 10 3]
Nov 21 19:14:34 RepetierServer kernel: [31623.886257]
isn't capable of
remote wakeup
Nov 21 19:14:34 RepetierServer kernel: [31623.897015]
rdware isn't capable of remote wakeup
Nov 21 19:14:34 RepetierServer dhcpcd[840]: eth0: waiting
for carrier
Nov 21 19:14:34 RepetierServer kernel: [31623.985927]
smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
<warn> (eth0): device not down after timeout!
Nov 21 19:14:34 RepetierServer kernel: [31623.998738] IPv6:
ADDRCONF(NETDEV_UP): eth0: link is not ready
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: carrier
acquired
Nov 21 19:14:36 RepetierServer kernel: [31625.459189] IPv6:
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Nov 21 19:14:36 RepetierServer kernel: [31625.460412]
smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
Nov 21 19:14:36 RepetierServer NetworkManager[442]:
<info> (eth0): link connected
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: adding
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: IAID
eb:69:7a:69
Nov 21 19:14:36 RepetierServer ModemManager[436]:
<warn> Couldn't find support for
device at '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1': not
supported by any plugin
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: rebinding
lease of 10.10.143.11
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: NAK: from
192.168.0.1
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: soliciting
an IPv6 router
a DHCP lease
Nov 21 19:14:36 RepetierServer dhcpcd[840]: eth0: offered
10.10.143.11 from 195.37.39.2
Hope this was right now.
Florian
