romas Hi all,I have problem a little bit similar like http://forum.repetier.com/discussion/3786/invisible-object-after-slicing<br/>G-code flavour I think is correct, RepRap (Marlin/Sprinter), G-code after slice look OK in slic3r, in green color. This generated G-code after opening in Repetier-Host look like without supports, only moves. What can be wrong?
so_what I had the same problem with slic3r, not printing support but making the moves. Other object same settings the support was very difficult to remove. Although i prefer Slic3r for my prints, i switched over to Cura when i print with supports
romas If I chose Slic3r Prusa Edition, in Slic3r I see the same picture, as in normal Slic3r, and after exporting G-code and importing it to Repetier I see supports...
romas What I must to use? Slic3r Prusa Edition has the same RepRap (Marlin/Sprinter), Cura also the same. They generate normal support, Slic3r V1.3.0-dev - not.
Repetier Have tested it with the 1.3dev we have bundled with Marlin/Sprinter flavour and I could see the support. SO please recheck and compare with prusa version where your differences are.
