Why do the speed color scale change from layer to layer. When visualizing a simple cube sliced with Slic3r, the color range for the top 3 layers is different than the rest. For example yellow will mean 60 for the top 3 layers but 45 for the others. This is visible if you switch the Visualization to Show Single Layer and scroll through the top layers. Maybe this has to do with the speed scale settings in Slic3r but it seems RH is not computing a consistent scale for all layers. It's difficult to visualize speeds if colors mean different things for different layers.
