Well did the manual bed adjustment and got it this even
Echo:N1036 G28
Info:Autoleveling disabled
Z-probe:6.337 X:0.00 Y:0.00
Z-probe:6.351 X:0.00 Y:200.00
Z-probe:6.343 X:150.00 Y:0.00
Z-probe:6.342 X:150.00 Y:200.00
plane: a = -0.0000 b = 0.0000 c = 6.3410
Transformation matrix: 1.000000 0.000000 0.000010 0.000000 1.000000 -0.000030 -0.000010 0.000030 1.000000
CurrentZ:6.34 atZ:6.35
Info:Autoleveling enabled
The result is now that both on far left side(out of the rectangle) and right side (inside of the rectangle), the bed composition is totally ignored or not done at all.
What am I doing wrong?Been at it now for a week and nothing to show for it.My EEPROM configuration
22:28:00.519 : EPR:0 1028 0 Language
22:28:00.519 : EPR:2 75 250000 Baudrate
22:28:00.534 : EPR:3 129 5.786 Filament printed [m]
22:28:00.534 : EPR:2 125 14510 Printer active [s]
22:28:00.534 : EPR:2 79 0 Max. inactive time [ms,0=off]
22:28:00.550 : EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
22:28:00.550 : EPR:3 3 200.7748 X-axis steps per mm
22:28:00.550 : EPR:3 7 197.9782 Y-axis steps per mm
22:28:00.565 : EPR:3 11 800.6468 Z-axis steps per mm
22:28:00.565 : EPR:3 15 200.000 X-axis max. feedrate [mm/s]
22:28:00.565 : EPR:3 19 200.000 Y-axis max. feedrate [mm/s]
22:28:00.581 : EPR:3 23 1.500 Z-axis max. feedrate [mm/s]
22:28:00.581 : EPR:3 27 40.000 X-axis homing feedrate [mm/s]
22:28:00.581 : EPR:3 31 40.000 Y-axis homing feedrate [mm/s]
22:28:00.597 : EPR:3 35 2.000 Z-axis homing feedrate [mm/s]
22:28:00.597 : EPR:3 39 20.000 Max. jerk [mm/s]
22:28:00.597 : EPR:3 47 0.510 Max. Z-jerk [mm/s]
22:28:00.597 : EPR:3 133 0.000 X min pos [mm]
22:28:00.612 : EPR:3 137 0.000 Y min pos [mm]
22:28:00.612 : EPR:3 141 0.000 Z min pos [mm]
22:28:00.628 : EPR:3 145 200.000 X max length [mm]
22:28:00.628 : EPR:3 149 200.000 Y max length [mm]
22:28:00.628 : EPR:3 153 185.000 Z max length [mm]
22:28:00.644 : EPR:3 51 1000.000 X-axis acceleration [mm/s
2]
22:28:00.644 : EPR:3 55 1000.000 Y-axis acceleration [mm/s
2]
22:28:00.644 : EPR:3 59 100.000 Z-axis acceleration [mm/s
2]
22:28:00.659 : EPR:3 63 1000.000 X-axis travel acceleration [mm/s
2]
22:28:00.659 : EPR:3 67 1000.000 Y-axis travel acceleration [mm/s
2]
22:28:00.659 : EPR:3 71 100.000 Z-axis travel acceleration [mm/s
2]
22:28:00.675 : EPR:3 1024 0.000 Coating thickness [mm]
22:28:00.675 : EPR:3 808 1.250 Z-probe height [mm]
22:28:00.784 : EPR:3 929 5.000 Max. z-probe - bed dist. [mm]
22:28:00.784 : EPR:3 812 2.000 Z-probe speed [mm/s]
22:28:00.784 : EPR:3 840 150.000 Z-probe x-y-speed [mm/s]
22:28:00.800 : EPR:3 800 38.000 Z-probe offset x [mm]
22:28:00.800 : EPR:3 804 0.000 Z-probe offset y [mm]
22:28:00.800 : EPR:3 816 0.000 Z-probe X1 [mm]
22:28:00.800 : EPR:3 820 0.000 Z-probe Y1 [mm]
22:28:00.800 : EPR:3 824 150.000 Z-probe X2 [mm]
22:28:00.815 : EPR:3 828 0.000 Z-probe Y2 [mm]
22:28:00.815 : EPR:3 832 0.000 Z-probe X3 [mm]
22:28:00.815 : EPR:3 836 200.000 Z-probe Y3 [mm]
22:28:00.815 : EPR:3 1036 0.000 Z-probe bending correction A [mm]
22:28:00.815 : EPR:3 1040 0.000 Z-probe bending correction B [mm]
22:28:00.831 : EPR:3 1044 0.000 Z-probe bending correction C [mm]
22:28:00.831 : EPR:0 880 1 Autolevel active (1/0)
22:28:00.831 : EPR:3 976 0.000000 tanXY Axis Compensation
22:28:00.831 : EPR:3 980 0.000000 tanYZ Axis Compensation
22:28:00.847 : EPR:3 984 0.000000 tanXZ Axis Compensation
22:28:00.847 : EPR:1 1048 55 Bed Preheat temp. [?C]
22:28:00.847 : EPR:0 106 0 Bed Heat Manager [0-3]
22:28:00.847 : EPR:0 107 255 Bed PID drive max
22:28:00.847 : EPR:0 124 80 Bed PID drive min
22:28:00.862 : EPR:3 108 196.000 Bed PID P-gain
22:28:00.862 : EPR:3 112 33.000 Bed PID I-gain
22:28:00.862 : EPR:3 116 290.000 Bed PID D-gain
22:28:00.862 : EPR:0 120 255 Bed PID max value [0-255]
22:28:00.862 : EPR:0 1020 0 Enable retraction conversion [0/1]
22:28:00.878 : EPR:3 992 3.000 Retraction length [mm]
22:28:00.878 : EPR:3 1000 40.000 Retraction speed [mm/s]
22:28:00.878 : EPR:3 1004 0.000 Retraction z-lift [mm]
22:28:00.878 : EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
22:28:00.894 : EPR:3 1016 20.000 Retraction undo speed
22:28:00.894 : EPR:3 200 213.200 Extr.1 steps per mm
22:28:00.894 : EPR:3 204 50.000 Extr.1 max. feedrate [mm/s]
22:28:00.894 : EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
22:28:00.894 : EPR:3 212 5000.000 Extr.1 acceleration [mm/s
2]
22:28:00.909 : EPR:1 294 190 Extr.1 Preheat temp. [?C]
22:28:00.909 : EPR:0 216 3 Extr.1 heat manager [0-3]
22:28:00.909 : EPR:0 217 230 Extr.1 PID drive max
22:28:00.909 : EPR:0 245 40 Extr.1 PID drive min
22:28:00.909 : EPR:3 218 7.0000 Extr.1 PID P-gain/dead-time
22:28:00.925 : EPR:3 222 2.0000 Extr.1 PID I-gain
22:28:00.925 : EPR:3 226 40.0000 Extr.1 PID D-gain
22:28:00.925 : EPR:0 230 255 Extr.1 PID max value [0-255]
22:28:00.925 : EPR:2 231 0 Extr.1 X-offset [steps]
22:28:00.925 : EPR:2 235 0 Extr.1 Y-offset [steps]
22:28:00.940 : EPR:2 290 0 Extr.1 Z-offset [steps]
22:28:00.940 : EPR:1 239 1 Extr.1 temp. stabilize time [s]
22:28:00.940 : EPR:1 250 150 Extr.1 temp. for retraction when heating [C]
22:28:00.940 : EPR:1 252 0 Extr.1 distance to retract when heating [mm]
22:28:00.956 : EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
22:28:00.956 : Echo:N1523 M205
