I tried another print, and the same thing seems to happen after the same amount of time. The print suddenly stops, and these weird beeping sounds start coming from the extruder. So i hit the "emergency stop" and when I heated the extruder, it worked fine, and the temperature rose. Here's the log when the print got interupted happened:
11:07:10.479 : N1448 M10530
11:07:10.492 : N1449 G0 X95.48 Y53.902 F4200*77
11:07:11.282 : N1450 G1 X93.698 Y52.12 E130.9974 F300063
11:07:11.284 : N1451 G0 X94.264 Y52.12 F4200*64
11:07:13.019 : N1452 M10521
11:07:13.822 : N1453 G1 X96.046 Y53.902 E131.1064 F3000*4
11:07:13.822 : N1454 G0 X93.352 Y60.26 F420064
11:07:15.598 : echo: cold extrusion prevented
11:07:15.599 : N1455 G1 X94.97 Y61.878 E131.2053 F3000*54
11:07:16.390 : echo: cold extrusion prevented
11:07:16.394 : N1456 M10517
11:07:16.400 : N1457 M104 T0 S0*22
11:07:18.134 : echo: cold extrusion prevented
11:07:18.138 : N1458 M104 T0 S25030
11:07:18.933 : echo: cold extrusion prevented
11:07:18.937 : N1459 M105*30
11:07:18.939 : N1460 G0 X94.405 Y61.878 F4200119
11:07:18.942 : N1461 G1 X93.352 Y60.826 E131.2697 F3000*8
11:07:18.949 : N1462 G0 X93.352 Y61.391 F4200123
11:07:20.707 : echo: cold extrusion prevented
11:07:20.710 : N1463 M104 T0 S0*17
11:07:20.717 : N1464 M104 T0 S25017
11:07:21.502 : echo: cold extrusion prevented
11:07:21.506 : N1465 G1 X93.839 Y61.878 E131.2995 F3000*13
11:07:23.243 : N1466 M10518
11:07:23.243 : N1467 G0 X93.531 Y61.702 Z1.7 F4200*33
11:07:23.247 : echo: cold extrusion prevented
11:07:24.041 : echo: cold extrusion prevented
11:07:24.047 : N1468 M104 T0 S0*26
11:07:24.047 : Printing layer 8 of 10
11:07:24.048 : N1469 G1 X93.528 Y58.385 E131.4429 F3600*5
11:07:25.815 : N1470 M105*21
11:07:25.815 : N1471 G1 X93.527 Y58.174 E131.452*84
11:07:25.819 : echo: cold extrusion prevented
11:07:26.614 : echo: cold extrusion prevented
11:07:26.620 : N1472 G1 X93.528 Y52.853 E131.6821*96
11:07:26.622 : echo: cold extrusion prevented
11:07:26.622 : N1473 G1 X93.527 Y52.589 E131.6935*96
11:07:28.351 : echo: cold extrusion prevented
11:07:28.355 : N1474 M105*17
11:07:28.355 : echo: cold extrusion prevented
11:07:29.154 : echo: cold extrusion prevented
11:07:29.158 : N1475 G1 X93.528 Y52.297 E131.7061*104
11:07:29.162 : echo: cold extrusion prevented
11:07:30.923 : echo: cold extrusion prevented
11:07:30.927 : N1476 G1 X95.897 Y52.295 E131.8086*96
11:07:30.930 : echo: cold extrusion prevented
11:07:30.930 : N1477 G1 X96.058 Y52.294 E131.8155*103
11:07:31.599 : echo: cold extrusion prevented
11:07:31.603 : N1478 M105*29
11:07:31.607 : echo: cold extrusion prevented
11:07:33.368 : echo: cold extrusion prevented
11:07:33.373 : N1479 G1 X100.413 Y52.295 E132.0038*92
11:07:33.376 : echo: cold extrusion prevented
11:07:34.167 : echo: cold extrusion prevented
11:07:34.172 : N1480 M105*26
11:07:34.172 : N1481 G1 X100.83 Y52.294 E132.0219*102
11:07:34.179 : echo: cold extrusion prevented
11:07:35.912 : echo: cold extrusion prevented
11:07:35.912 : N1482 G1 X104.468 Y52.297 E132.1792*84
11:07:35.920 : echo: cold extrusion prevented
11:07:35.924 : N1483 G1 X104.471 Y55.614 E132.3226*93
11:07:39.054 : echo: cold extrusion prevented
11:07:39.059 : N1484 M105*30
11:07:39.062 : echo: cold extrusion prevented
11:07:40.730 : echo: cold extrusion prevented
11:07:40.734 : N1485 M105*31
11:07:40.734 : N1486 M107 P0*94
11:07:40.738 : echo: cold extrusion prevented
11:07:41.532 : echo: cold extrusion prevented
11:07:41.536 : N1487 G1 X104.472 Y55.825 E132.3317*85
11:07:41.539 : N1488 G1 X104.471 Y61.146 E132.5618*94
11:07:41.542 : N1489 G1 X104.472 Y61.41 E132.5732*99
11:07:41.543 : echo: cold extrusion prevented
11:07:42.855 : echo: cold extrusion prevented
11:07:42.860 : N1490 G1 X104.471 Y61.702 E132.5858*91
11:07:42.863 : echo: cold extrusion prevented
11:07:43.654 : echo: cold extrusion prevented
11:07:43.658 : N1491 M105*26
11:07:43.662 : echo: cold extrusion prevented
11:07:44.526 : echo: cold extrusion prevented
11:07:44.535 : echo: cold extrusion prevented
11:07:44.535 : N1492 G1 X102.102 Y61.704 E132.6882*92
11:07:45.198 : echo: cold extrusion prevented
11:07:45.202 : N1493 G1 X101.941 Y61.705 E132.6952*92
11:07:45.210 : echo: cold extrusion prevented
11:07:45.211 : N1494 G1 X97.586 Y61.704 E132.8835*109
11:07:46.780 : echo: cold extrusion prevented
11:07:46.788 : echo: cold extrusion prevented
11:07:46.788 : N1495 M105*30
11:07:46.849 : echo: cold extrusion prevented
11:07:46.857 : N1496 G1 X97.169 Y61.705 E132.9015*96
11:07:46.861 : echo: cold extrusion prevented
11:07:48.705 : echo: cold extrusion prevented
11:07:48.715 : N1497 G1 X93.531 Y61.702 E133.0588*98
11:07:48.717 : N1498 G0 X93.131 Y62.101 F4200*113
11:07:48.717 : echo: cold extrusion prevented
11:07:48.872 : echo: cold extrusion prevented
11:07:48.881 : echo: cold extrusion prevented
11:07:48.881 : N1499 G1 X93.127 Y52.587 E133.4702 F3600*7
11:07:49.286 : echo: cold extrusion prevented
11:07:49.290 : N1500 G1 X93.13 Y51.898 E133.5*103
11:07:50.561 : N1501 M105*18
11:07:50.564 : echo: cold extrusion prevented
11:07:50.610 : echo: cold extrusion prevented
11:07:50.618 : echo: cold extrusion prevented
11:07:50.618 : N1502 G1 X95.896 Y51.895 E133.6196*102
11:07:52.068 : echo: cold extrusion prevented
11:07:52.072 : N1503 G1 X96.055 Y51.894 E133.6265*109
11:07:52.080 : echo: cold extrusion prevented
11:07:52.085 : N1504 G1 X104.868 Y51.898 E134.0075*88
11:07:52.207 : echo: cold extrusion prevented
11:07:52.211 : N1505 G1 X104.872 Y61.412 E134.4189*89
11:07:52.215 : echo: cold extrusion prevented
11:07:53.887 : echo: cold extrusion prevented
11:07:53.890 : N1506 M105*21
11:07:53.894 : echo: cold extrusion prevented
11:07:55.476 : echo: cold extrusion prevented
11:07:55.480 : echo: cold extrusion prevented
11:07:55.480 : N1507 M105*20
11:07:55.480 : N1508 G1 X104.869 Y62.101 E134.4487*81
11:07:55.545 : echo: cold extrusion prevented
11:07:55.556 : N1509 G1 X102.103 Y62.104 E134.5683*81
11:07:55.564 : echo: cold extrusion prevented
11:07:55.565 : N1510 G1 X101.944 Y62.105 E134.5752*93
11:07:57.401 : echo: cold extrusion prevented
11:07:57.409 : echo: cold extrusion prevented
11:07:57.409 : N1511 G1 X93.131 Y62.101 E134.9562*101
11:07:57.569 : echo: cold extrusion prevented
11:07:57.573 : N1512 G0 X93.718 Y61.562 F4200*125
11:07:57.577 : echo: cold extrusion prevented
11:07:57.982 : echo: cold extrusion prevented
11:07:57.987 : echo: cold extrusion prevented
11:07:57.987 : N1513 G1 X102.843 Y52.436 E135.5142 F3000*62
11:07:59.252 : echo: cold extrusion prevented
11:07:59.264 : N1514 M104 T0 S250*23
11:07:59.264 : N1515 M105*23
11:07:59.310 : N1516 G0 X102.278 Y52.436 F4200*67
11:07:59.316 : echo: cold extrusion prevented
11:08:00.760 : echo: cold extrusion prevented
11:08:00.776 : N1517 M104 T0 S0*19
11:08:00.778 : N1518 G1 X93.67 Y61.044 E136.0406 F3000*48
11:08:00.907 : N1519 G0 X93.67 Y60.478 F4200*66
11:08:00.908 : N1520 G1 X101.712 Y52.436 E136.5323 F3000*48
11:08:00.911 : echo: cold extrusion prevented
11:08:02.567 : echo: cold extrusion prevented
11:08:02.571 : N1521 M105*16
11:08:03.357 : echo: cold extrusion prevented
11:08:03.357 : N1522 G0 X101.146 Y52.436 F4200*73
11:08:07.072 : echo: cold extrusion prevented
11:08:07.077 : N1523 M105*18
11:08:07.077 : N1524 G1 X93.67 Y59.913 E136.9895 F3000*48
11:08:07.719 : N1525 M105*20
11:08:07.721 : N1526 G0 X93.669 Y59.348 F4200*120
11:08:07.723 : echo: cold extrusion prevented
11:08:09.116 : echo: cold extrusion prevented
11:08:09.127 : N1527 G1 X100.58 Y52.436 E137.4121 F3000*15
11:08:09.128 : N1528 G0 X100.015 Y52.436 F4200*69
11:08:09.178 : echo: cold extrusion prevented
11:08:09.178 : N1529 G1 X93.669 Y58.782 E137.8002 F3000*4
11:08:12.585 : echo: cold extrusion prevented
11:08:12.590 : N1530 M105*16
11:08:15.440 : Printer reset detected - initalizing
What was worrying me most was the beeping sound that gradually gained a higher frequency. Any idea if that's a sign of anything?
