I've recently ordered two TMC2100 for replace the DRV8826 in my corexy based on ramps.
I've set the TMC2100 in 1/16 - spreadCycle, then I've reverse the direction of the motor and change the step/mm for X and Y axis...
I've print the classic test cube, and now the printer loose a lots of steps...
So I've decrease the acceleration from 1500mm/s to 1000mm/s in X and Y axis, but nothing change...
Actually the jerk on XY is 20, i could try to decrease it and test again...
Could be possible that the quadstepping feature in the firmware are not fully compatible with the TMC2100?
There is some settings/delay for quadstepping and TMC2100?
