Ok, i did it from start:
- checked configuration.h with repetier configuration tool on homepage
- compiled it, uploaded it, M502, M500
- run home, centered extruder G131
- justified the sliders, M99 X0 ..., for all towers
- measured and saved bed levels, G32 S2
Here i got the first problem: the measuring was ok but the measured (and saved) height was 311.59mm, but the real height is 271,90. What's wrong here?
- corrected the height in eeprom setup in repetier host
- run home and then down near the bed, G0 Z5 F1000
- startet height map in repetier host, saved the values to text file
- measured distortion matrix, G33
- without any movement the error message in repetier host log:
13:51:21.166 : Error:Bpos x square
13:51:21.173 : Warning:Invalid delta coordinate - move ignored x:-5368 y:7071 z:3375
13:51:21.181 : Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
13:51:21.184 : Warning:moveToReal / queueDeltaMove returns error
Seems to be a big problem in repetier firmware ??
