did G32 S2:
the following are the results.
13:46:40.147 : plane: a = -0.0011 b = -0.0070 c = 25.4747
13:46:40.147 : Transformation matrix: 0.999999 0.000000 0.001085 -0.000008 0.999976 0.006971 -0.001085 -0.006971 0.999975
13:46:40.147 : CurrentZ:25.01 atZ:25.00
13:46:40.147 : Z after rotation:25.00
13:46:40.147 : Printer height:180.69
13:46:41.149 : Info:Autoleveling enabled
13:46:41.149 : X:45.03 Y:45.17 Z:24.550 E:0.0000
13:46:41.149 : Info:Autoleveling disabled
13:46:48.820 : SelectExtruder:0
13:46:48.848 : X:0.00 Y:0.00 Z:180.694 E:0.0000
13:46:48.848 : Info:Autoleveling enabled
still a 5 point matrix, but tried to increase the correction radius from 55 to 90.
but am not sure this actually worked (still to small when actually measuring)
also i would like that more matrix points
and know which values (names) to look for to calculate the actual: DISTORTION_UPDATE_FREQUENCY
max speed = MAX travel speed (X=Y=Z)?? and what is a good value.. it is now set as 400 with resolution at 160 and 1/32.
but where do i find updates per second?
also to store the transformation matrix in the eeprom should the eeprom mode be enabled (1 or 2) or can it be disabled)
Also is there a simple formula to calculate the correct, correction radius taking the platform diameter and correction points per axis. As this gets a lot more complicated when this will get more then (say 9)
Kind regards
Matthieu
