Hello all,
i'l new in 3d printer and i work on mac 10.6.8 when install repetier 0.56 it's ok but in repetier there is a slic3r and in may librayry/support application/slice3r i have a a 3 file filament, print and printer and slic3r.ini but this 3 files is empty and in repetier i don't have access to the roll panel print setting printer setting and filament beacause is empty .
When i slice is ok but when i run g-code he tell me print stopped du errors fix the error and use M999 to restart ( temperature is reset, Set it after restarting). How can i fix the problem with the folder for slic3r
If you have an idea it's great
Thank's a lot in advance to read me and good eveninf for everything
