harristhepoodle I am new to repetier, and I have tried homing the x and y axis, however they go to the other end, away from the endstop. I have tried inverting them, but the problem still continues. Is there any solution?
Repetier You must configure this in your firmware. there is a invert option for every axis. Alternative rotate motor connector 180° which also inverts direction.
harristhepoodle Repetier said: You must configure this in your firmware. there is a invert option for every axis. Alternative rotate motor connector 180° which also inverts direction. where to configure?
Repetier You modify your firmware configuration and reupload it to printer. Where depends on firmware.
Repetier In config tool just hit the invert direction checkbox in the axis configuration. Alternatively if you configure by hand in Configuration.h change INVERT_Y_DIR and INVERT_Z_DIR between 0 and 1.
