Good day Repetier,
I have set up a diamond head on a delta, and I configured mixing and set my slicer to use G10/G11 retract/restore.
But I see that if I print with a color that only use one extruder, then G10/G11 effects all the extruder motors equally.
The down side of this is that if I set the Extra Restore Distance to -0.1mm(to try and combat blobs at start of lines) then the extruders that are not active, and don't feed much during the print, loose 0.1 for every restore, eventually retracting so far that the filament jams in the head. This happens because the restore removes -0.1mm from all motors on every retract of the printing motor, and as the second/third motor is not actually printing, that 0.1mm is never caught up and gets worse and worse.
This is my experience, but I might be wrong.
Any thoughts?
Thank you,
Errol
