Well - I would hope for another solution.
I have a newly set up Printer with three-Z-Motors for bed level correction, and it is almost perfekt. But I still want to home to zmin, because there is a micrometer screw to adjust bed Level Distance. I would like to make a pre-Z-Homing with the probe (because a badly tilted bed delivers wrong heights to z-Min-Endstop. Wich could result in a nozzle crash.)
The sequence I have in mind is: Where ever it is, lower the board with g1 z10. After that, homing xy, then going to the middle (xy). Homing Z Min with probe, going back 10 mm from switch point, doing the G32 stuff (disabling zmin Endstop, otherwise you have the Z-Min-Endstop firing before the probe hits - would be perfect), then homing to zmin with conventional Endstop.
Question is about the Homing with Z Probe with a magical Gcode sequence and still having a conventinal Zmin-Endstop with a micrometer screw available. I love that screw because it works fine, but I don't want to fix it to the printer head.
