<font face="Arial, Verdana">/</font>
<font face="Arial, Verdana"> This file is part of Repetier-Firmware.</font>
</font>
<font face="Arial, Verdana"> Repetier-Firmware is free software: you can redistribute it and/or modify</font>
<font face="Arial, Verdana"> it under the terms of the GNU General Public License as published by</font>
<font face="Arial, Verdana"> the Free Software Foundation, either version 3 of the License, or</font>
<font face="Arial, Verdana"> (at your option) any later version.</font>
</font>
<font face="Arial, Verdana"> Repetier-Firmware is distributed in the hope that it will be useful,</font>
<font face="Arial, Verdana"> but WITHOUT ANY WARRANTY; without even the implied warranty of</font>
<font face="Arial, Verdana"> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the</font>
<font face="Arial, Verdana"> GNU General Public License for more details.</font>
</font>
<font face="Arial, Verdana"> You should have received a copy of the GNU General Public License</font>
<font face="Arial, Verdana"> along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.</span></font></div><div><font face="Arial, Verdana">
</font>
<font face="Arial, Verdana">*/</font>
</font>
<font face="Arial, Verdana">#ifndef CONFIGURATION_H</font>
<font face="Arial, Verdana">#define CONFIGURATION_H</font>
</font>
<font face="Arial, Verdana">/**************** READ FIRST ***********************</font>
</font>
<font face="Arial, Verdana"> This configuration file was created with the configuration tool. For that</font>
<font face="Arial, Verdana"> reason, it does not contain the same informations as the original Configuration.h file.</font>
<font face="Arial, Verdana"> It misses the comments and unused parts. Open this file file in the config tool</font>
<font face="Arial, Verdana"> to see and change the data. You can also upload it to newer/older versions. The system</font>
<font face="Arial, Verdana"> will silently add new options, so compilation continues to work.</font>
</font>
<font face="Arial, Verdana"> This file is optimized for version 0.92</font>
<font face="Arial, Verdana"> generator: http://www.repetier.com/firmware/v092/</span></font></div><div><font face="Arial, Verdana">
</font>
<font face="Arial, Verdana"> If you are in doubt which named functions use which pins on your board, please check the</font>
<font face="Arial, Verdana"> pins.h for the used name->pin assignments and your board documentation to verify it is</font>
<font face="Arial, Verdana"> as you expect.</font>
</font>
</font>
<font face="Arial, Verdana">#define NUM_EXTRUDER 1</font>
<font face="Arial, Verdana">#define MOTHERBOARD 33</font>
<font face="Arial, Verdana">#include "pins.h"</font>
</font>
<font face="Arial, Verdana">// ################## EDIT THESE SETTINGS MANUALLY ################</font>
<font face="Arial, Verdana">// ################ END MANUAL SETTINGS ##########################</font>
</font>
<font face="Arial, Verdana">#undef FAN_BOARD_PIN</font>
<font face="Arial, Verdana">#define FAN_BOARD_PIN -1</font>
<font face="Arial, Verdana">#define BOARD_FAN_SPEED 255</font>
<font face="Arial, Verdana">#define FAN_THERMO_PIN -1</font>
<font face="Arial, Verdana">#define FAN_THERMO_MIN_PWM 128</font>
<font face="Arial, Verdana">#define FAN_THERMO_MAX_PWM 255</font>
<font face="Arial, Verdana">#define FAN_THERMO_MIN_TEMP 45</font>
<font face="Arial, Verdana">#define FAN_THERMO_MAX_TEMP 60</font>
<font face="Arial, Verdana">#define FAN_THERMO_THERMISTOR_PIN -1</font>
<font face="Arial, Verdana">#define FAN_THERMO_THERMISTOR_TYPE 1</font>
</font>
<font face="Arial, Verdana">//#define EXTERNALSERIAL use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.</font>
<font face="Arial, Verdana">// Uncomment the following line if you are using Arduino compatible firmware made for Arduino version earlier then 1.0</font>
<font face="Arial, Verdana">// If it is incompatible you will get compiler errors about write functions not being compatible!</font>
<font face="Arial, Verdana">//#define COMPAT_PRE1</font>
<font face="Arial, Verdana">#define BLUETOOTH_SERIAL -1</font>
<font face="Arial, Verdana">#define BLUETOOTH_BAUD 115200</font>
<font face="Arial, Verdana">#define MIXING_EXTRUDER 0</font>
</font>
<font face="Arial, Verdana">#define DRIVE_SYSTEM 0</font>
<font face="Arial, Verdana">#define XAXIS_STEPS_PER_MM 320</font>
<font face="Arial, Verdana">#define YAXIS_STEPS_PER_MM 200</font>
<font face="Arial, Verdana">#define ZAXIS_STEPS_PER_MM 10240</font>
<font face="Arial, Verdana">#define EXTRUDER_FAN_COOL_TEMP 50</font>
<font face="Arial, Verdana">#define PDM_FOR_EXTRUDER 0</font>
<font face="Arial, Verdana">#define PDM_FOR_COOLER 0</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MIN_TEMP_RISE 1</font>
<font face="Arial, Verdana">#define KILL_IF_SENSOR_DEFECT 0</font>
<font face="Arial, Verdana">#define RETRACT_ON_PAUSE 2</font>
<font face="Arial, Verdana">#define PAUSE_START_COMMANDS ""</font>
<font face="Arial, Verdana">#define PAUSE_END_COMMANDS ""</font>
<font face="Arial, Verdana">#define SHARED_EXTRUDER_HEATER 0</font>
</font>
<font face="Arial, Verdana">#define EXT0_X_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Y_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Z_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_STEPS_PER_MM 370</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_TYPE 13</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_HEATER_PIN HEATER_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_STEP_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE 0</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_ON 0</font>
<font face="Arial, Verdana">#define EXT0_MIRROR_STEPPER 0</font>
<font face="Arial, Verdana">#define EXT0_STEP2_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR2_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE2 0</font>
<font face="Arial, Verdana">#define EXT0_ENABLE2_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_MAX_FEEDRATE 50</font>
<font face="Arial, Verdana">#define EXT0_MAX_START_FEEDRATE 20</font>
<font face="Arial, Verdana">#define EXT0_MAX_ACCELERATION 5000</font>
<font face="Arial, Verdana">#define EXT0_HEAT_MANAGER 3</font>
<font face="Arial, Verdana">#define EXT0_WATCHPERIOD 1</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MAX 230</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MIN 40</font>
<font face="Arial, Verdana">#define EXT0_PID_PGAIN_OR_DEAD_TIME 7</font>
<font face="Arial, Verdana">#define EXT0_PID_I 2</font>
<font face="Arial, Verdana">#define EXT0_PID_D 40</font>
<font face="Arial, Verdana">#define EXT0_PID_MAX 255</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_K 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_L 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_BACKLASH_STEPS 0</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_TEMP 150</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_UNITS 0</font>
<font face="Arial, Verdana">#define EXT0_SELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_DESELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_PIN -1</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_SPEED 255</font>
<font face="Arial, Verdana">#define EXT0_DECOUPLE_TEST_PERIOD 12000</font>
<font face="Arial, Verdana">#define EXT0_JAM_PIN -1</font>
<font face="Arial, Verdana">#define EXT0_JAM_PULLUP 0</font>
</font>
</font>
<font face="Arial, Verdana">#define FEATURE_RETRACTION 1</font>
<font face="Arial, Verdana">#define AUTORETRACT_ENABLED 0</font>
<font face="Arial, Verdana">#define RETRACTION_LENGTH 3</font>
<font face="Arial, Verdana">#define RETRACTION_LONG_LENGTH 13</font>
<font face="Arial, Verdana">#define RETRACTION_SPEED 40</font>
<font face="Arial, Verdana">#define RETRACTION_Z_LIFT 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_SPEED 20</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_X_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Y_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Z_ADD 2</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_REHOME 1</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_SHORTRETRACT 5</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_LONGRETRACT 50</font>
<font face="Arial, Verdana">#define JAM_STEPS 220</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_STEPS 320</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_TO 70</font>
<font face="Arial, Verdana">#define JAM_ERROR_STEPS 500</font>
<font face="Arial, Verdana">#define JAM_MIN_STEPS 10</font>
<font face="Arial, Verdana">#define JAM_ACTION 1</font>
</font>
<font face="Arial, Verdana">#define RETRACT_DURING_HEATUP true</font>
<font face="Arial, Verdana">#define PID_CONTROL_RANGE 20</font>
<font face="Arial, Verdana">#define SKIP_M109_IF_WITHIN 2</font>
<font face="Arial, Verdana">#define SCALE_PID_TO_MAX 0</font>
<font face="Arial, Verdana">#define TEMP_HYSTERESIS 0</font>
<font face="Arial, Verdana">#define EXTRUDE_MAXLENGTH 160</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR0 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE0 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR1 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE1 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR2 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE2 {}</font>
<font face="Arial, Verdana">#define GENERIC_THERM_VREF 5</font>
<font face="Arial, Verdana">#define GENERIC_THERM_NUM_ENTRIES 33</font>
<font face="Arial, Verdana">#define HEATER_PWM_SPEED 0</font>
</font>
<font face="Arial, Verdana">// ############# Heated bed configuration ########################</font>
</font>
<font face="Arial, Verdana">#define HAVE_HEATED_BED 1</font>
<font face="Arial, Verdana">#define HEATED_BED_MAX_TEMP 120</font>
<font face="Arial, Verdana">#define SKIP_M190_IF_WITHIN 3</font>
<font face="Arial, Verdana">#define HEATED_BED_SENSOR_TYPE 1</font>
<font face="Arial, Verdana">#define HEATED_BED_SENSOR_PIN TEMP_1_PIN</font>
<font face="Arial, Verdana">#define HEATED_BED_HEATER_PIN HEATER_1_PIN</font>
<font face="Arial, Verdana">#define HEATED_BED_SET_INTERVAL 5000</font>
<font face="Arial, Verdana">#define HEATED_BED_HEAT_MANAGER 0</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 196</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_IGAIN 33</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_DGAIN 290</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_MAX 255</font>
<font face="Arial, Verdana">#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000</font>
<font face="Arial, Verdana">#define MIN_EXTRUDER_TEMP 150</font>
<font face="Arial, Verdana">#define MAXTEMP 275</font>
<font face="Arial, Verdana">#define MIN_DEFECT_TEMPERATURE -10</font>
<font face="Arial, Verdana">#define MAX_DEFECT_TEMPERATURE 290</font>
