Negative values are only possible if extruder presses the bed for probing. In all other cases it must be positive otherwise your nozzle would need to go through bed to trigger nozzle.
Important is the distance when probe triggers not the physical distance. So if you have a inductive sensor this is above nozzle height but triggers before nozzle hits bed so you still have a positive distance for trigger-nozzle distance.
