gorf25 I have the baud rate set at 240000 but when I go to connect I have to use 115200 or I can't connect if I flash marlin it will connect at 240000.any suggestions?Gary
Repetier 240000 is not supported anywhere. You mean 250000 i guess.Repetier stores baud rate in eeprom, so connect with 115200 since that works go to eeprom editor and set baud rate to 250000 and reconnect with that speed.
