daniro PRINTER GEETECH PRUSA I3 ALMINUM PRINTS FEW LAYERS AND THAN CONTINUES TO PRINT IN THE AIR (ABOUT 2 mm) overany suggestions? thanks
daniro Where is the Z control. The slic3r generates the code. And there movments in Z by layer hight i geuss
MartinH Check your Z movment steps calibration, home Z then send a G1 Z100 measure how far Z actually does move
daniro Z 100 IN SOFTWARE IS Z100 IN REALTY, WHEN I PRINT I NOTICES THERE IS 2 mm offset for some reason from the value that is shown to acctual value., for example 4 is 6, etc.and it isn't the z offset value, becuase it is set to -0.5.any ideas?
Repetier Show first 100 lines of gcode not counting comments. As I said if homing goes to z=0 and G1 Z1 has 1mm then it is in gcode you send. If the simple test fails your configuration has a problem.
