daniro Z AXIS PHYSICAL LIMIT IS 250 mm, when i input a value of 25 to Z IT GOES TO THE UPPER LIMIT. (IT SAYS IT'S mm UNITS BUT... SEEMS TO BE IN cm?MY PRINTER IS GEETECH PRUSA ALUMINUM I3 , FIRMWARE REPTIER MARYLINTHANKS FOR YOUR HELP
MartinH seems like you have the z steps/mm set wrong in your firmware What type Z rods are fitted? M5 threaded rods, M8 threaded rods or M8 4 start lead screws ?
MartinH <font face="Arial, Verdana">426 is more a 4 start lead screw size</font>make sure you have the 3 jumpers installed under each 4998 driver pcb to set 1/16 microsteping.
