Hello,
I bought kossel mini from he3d and assembled but now I have faced
serious issue. I am struggling to get it working since last 15 days.
Steps I perform to start my printer.
My printer has J hot end with fan, no bed.
1) Connections done as it should be
2) Press home button : ====> all x,y and z move to top of the printers and stop properly at end switches.
when
I try to move nozzle down to calibrate it, nozzle is moving in front
direction ---> it should straight go in middle of the bed but it is
going to -Y direction always.
so uptill it reaches near to bed it will be to -Y direction totally instead of being at centre.
I believe Z axis motor is taking more steps so it is forcing nozzle to move more in -Y direction
With which Repetier product you have a problem?
==> Repetier 1.06
Which software version are you using? (We support only the latest version. If you use an older version, update your software and check if the error has been corrected ===> Repetier 1.06
Operating system type and version ===> Win 7
Detailed error description ===> Z axis in the kossel covers 200 mm while x and y takes only 100mm distance. They should be in sync to get the nozzle to centre.
Steps to reproduce the error ===> Attaching configuration.h file ===> reproduced every time ===> http://youtu.be/NVSitSj5BYE
Attach required files including configuration files to reproduce the error.===> attaching configuration.h file : http://pastebin.com/5UJcgauj<br/>If the error occurs during printing, with which printer you work? ===> not able to start the printing due to issue.
