<font face="Arial, Verdana">Here is an update.. I have been able to work around the buggy USB stack on the PI. It was actually my cameras that were crashing the USB stack on the pi not the printers. Anyways to work around the issue I added the following to the command line of the kernel:</font>
<font face="Arial, Verdana">dwc_otg.otg_cap=2 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 dwc_otg.lpm_enable=0</font>
</font>
<font face="Arial, Verdana">I don't know which specific option fixed my previous problem.</font>
</font>
<font face="Arial, Verdana">Now I have a new issue. Repetier Server crashed during a print and won't restart. </font>
</font>
<font face="Arial, Verdana">Here is a capture of the logs:</font>
<font face="Arial, Verdana">Repetier Server log:</font>
2017-02-10 20:10:21: Start logging...
2017-02-10 20:10:21: Webdirectory: /usr/local/Repetier-Server/www/
2017-02-10 20:10:21: Storage directory: /var/lib/Repetier-Server/
2017-02-10 20:10:21: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2017-02-10 20:10:21: Directory for temporary files: /tmp/
2017-02-10 20:10:21: Reading firmware data ...
2017-02-10 20:10:21: Starting Network ...
2017-02-10 20:10:21: Active features:4095
2017-02-10 20:10:21: Reading printer configurations ...
2017-02-10 20:10:21: Reading printer config /var/lib/Repetier-Server/configs/Prusa_I3_MK2.xml
2017-02-10 20:10:21: Starting printjob manager thread for Prusa_I3_MK2
2017-02-10 20:10:21: Reading printer config /var/lib/Repetier-Server/configs/Tevo_Black_Widow.xml
2017-02-10 20:10:21: Starting printjob manager thread for Tevo_Black_Widow
2017-02-10 20:10:21: Reading printer config /var/lib/Repetier-Server/configs/Monoprice_Maker_Ultimate.xml
2017-02-10 20:10:21: Starting printjob manager thread for Monoprice_Maker_Ultimate
2017-02-10 20:10:21: Starting printer threads ...
2017-02-10 20:10:21: Starting printer thread for Prusa_I3_MK2
2017-02-10 20:10:21: Starting printer thread for Tevo_Black_Widow
2017-02-10 20:10:21: Starting printer thread for Monoprice_Maker_Ultimate
2017-02-10 20:10:21: Starting work dispatcher subsystem ...
2017-02-10 20:10:21: Starting user database ...
2017-02-10 20:10:21: Initalizing LUA ...
2017-02-10 20:10:21: Register LUA cloud services
2017-02-10 20:10:21: add Repetier-Renderer
2017-02-10 20:10:21: LUA initalization finished.
2017-02-10 20:10:21: Starting web server ...
2017-02-10 20:10:21: Work dispatcher thread started.
2017-02-10 20:10:21: Webserver started.
2017-02-10 20:10:22: Start logging...
2017-02-10 20:10:22: Webdirectory: /usr/local/Repetier-Server/www/
2017-02-10 20:10:22: Storage directory: /var/lib/Repetier-Server/
2017-02-10 20:10:22: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2017-02-10 20:10:22: Directory for temporary files: /tmp/
2017-02-10 20:10:22: Reading firmware data ...
2017-02-10 20:10:22: Starting Network ...
2017-02-10 20:10:22: Active features:4095
2017-02-10 20:10:22: Reading printer configurations ...
2017-02-10 20:10:22: Reading printer config /var/lib/Repetier-Server/configs/Prusa_I3_MK2.xml
2017-02-10 20:10:22: Starting printjob manager thread for Prusa_I3_MK2
2017-02-10 20:10:22: Reading printer config /var/lib/Repetier-Server/configs/Tevo_Black_Widow.xml
2017-02-10 20:10:22: Starting printjob manager thread for Tevo_Black_Widow
2017-02-10 20:10:22: Reading printer config /var/lib/Repetier-Server/configs/Monoprice_Maker_Ultimate.xml
2017-02-10 20:10:22: Starting printjob manager thread for Monoprice_Maker_Ultimate
2017-02-10 20:10:22: Starting printer threads ...
2017-02-10 20:10:22: Starting printer thread for Prusa_I3_MK2
2017-02-10 20:10:22: Starting printer thread for Tevo_Black_Widow
2017-02-10 20:10:22: Starting printer thread for Monoprice_Maker_Ultimate
2017-02-10 20:10:22: Starting work dispatcher subsystem ...
2017-02-10 20:10:22: Starting user database ...
2017-02-10 20:10:22: Initalizing LUA ...
2017-02-10 20:10:22: Register LUA cloud services
2017-02-10 20:10:22: add Repetier-Renderer
2017-02-10 20:10:22: LUA initalization finished.
2017-02-10 20:10:22: Starting web server ...
2017-02-10 20:10:22: Work dispatcher thread started.
2017-02-10 20:10:22: Webserver started.
syslog:
Feb 10 20:10:21 systemd[1]: Starting Repetier-Server 3D Printer Server...
Feb 10 20:10:21 systemd[1]: Started Repetier-Server 3D Printer Server.
Feb 10 20:10:21 systemd[1]: RepetierServer.service: main process exited, code=killed, status=6/ABRT
Feb 10 20:10:21 systemd[1]: Unit RepetierServer.service entered failed state.
Feb 10 20:10:21 systemd[1]: RepetierServer.service has no holdoff time, scheduling restart.
Feb 10 20:10:21 systemd[1]: Stopping Repetier-Server 3D Printer Server...
Feb 10 20:10:22 systemd[1]: Started Repetier-Server 3D Printer Server.
Feb 10 20:10:22 systemd[1]: RepetierServer.service: main process exited, code=killed, status=6/ABRT
Feb 10 20:10:22 systemd[1]: Unit RepetierServer.service entered failed state.
Feb 10 20:10:22 systemd[1]: RepetierServer.service has no holdoff time, scheduling restart.
Feb 10 20:10:22 systemd[1]: Stopping Repetier-Server 3D Printer Server...
Feb 10 20:10:22 systemd[1]: Starting Repetier-Server 3D Printer Server...
Feb 10 20:10:22 systemd[1]: RepetierServer.service start request repeated too quickly, refusing to start.
Feb 10 20:10:22 systemd[1]: Failed to start Repetier-Server 3D Printer Server.
What else can I check or try to get it running again?
-Rob
</font>
