<font face="Arial, Verdana">
</font>
<font face="Arial, Verdana">#define DRIVE_SYSTEM 0</font>
<font face="Arial, Verdana">#define XAXIS_STEPS_PER_MM 200</font>
<font face="Arial, Verdana">#define YAXIS_STEPS_PER_MM 200</font>
<font face="Arial, Verdana">#define ZAXIS_STEPS_PER_MM 8000</font>
<font face="Arial, Verdana">#define EXTRUDER_FAN_COOL_TEMP 50</font>
<font face="Arial, Verdana">#define PDM_FOR_EXTRUDER 0</font>
<font face="Arial, Verdana">#define PDM_FOR_COOLER 0</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MIN_TEMP_RISE 1</font>
<font face="Arial, Verdana">#define KILL_IF_SENSOR_DEFECT 0</font>
<font face="Arial, Verdana">#define RETRACT_ON_PAUSE 2</font>
<font face="Arial, Verdana">#define PAUSE_START_COMMANDS ""</font>
<font face="Arial, Verdana">#define PAUSE_END_COMMANDS ""</font>
<font face="Arial, Verdana">#define SHARED_EXTRUDER_HEATER 0</font>
<font face="Arial, Verdana">#define EXT0_X_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Y_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Z_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_STEPS_PER_MM 237.037</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_TYPE 1</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_HEATER_PIN HEATER_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_STEP_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE 1</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_ON 0</font>
<font face="Arial, Verdana">#define EXT0_MIRROR_STEPPER 0</font>
<font face="Arial, Verdana">#define EXT0_STEP2_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR2_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE2 0</font>
<font face="Arial, Verdana">#define EXT0_ENABLE2_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_MAX_FEEDRATE 10</font>
<font face="Arial, Verdana">#define EXT0_MAX_START_FEEDRATE 10</font>
<font face="Arial, Verdana">#define EXT0_MAX_ACCELERATION 1000</font>
<font face="Arial, Verdana">#define EXT0_HEAT_MANAGER 3</font>
<font face="Arial, Verdana">#define EXT0_WATCHPERIOD 1</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MAX 230</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MIN 40</font>
<font face="Arial, Verdana">#define EXT0_PID_PGAIN_OR_DEAD_TIME 7</font>
<font face="Arial, Verdana">#define EXT0_PID_I 2</font>
<font face="Arial, Verdana">#define EXT0_PID_D 40</font>
<font face="Arial, Verdana">#define EXT0_PID_MAX 255</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_K 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_L 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_BACKLASH_STEPS 0</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_TEMP 150</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_UNITS 0</font>
<font face="Arial, Verdana">#define EXT0_SELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_DESELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_PIN HEATER_2_PIN</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_SPEED 255</font>
<font face="Arial, Verdana">#define EXT0_DECOUPLE_TEST_PERIOD 12000</font>
<font face="Arial, Verdana">#define EXT0_JAM_PIN -1</font>
<font face="Arial, Verdana">#define EXT0_JAM_PULLUP 0</font>
</font>
<font face="Arial, Verdana">#define FEATURE_RETRACTION 1</font>
<font face="Arial, Verdana">#define AUTORETRACT_ENABLED 0</font>
<font face="Arial, Verdana">#define RETRACTION_LENGTH 3</font>
<font face="Arial, Verdana">#define RETRACTION_LONG_LENGTH 13</font>
<font face="Arial, Verdana">#define RETRACTION_SPEED 40</font>
<font face="Arial, Verdana">#define RETRACTION_Z_LIFT 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_SPEED 20</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_X_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Y_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Z_ADD 2</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_REHOME 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_SHORTRETRACT 5</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_LONGRETRACT 50</font>
<font face="Arial, Verdana">#define JAM_STEPS 220</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_STEPS 320</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_TO 70</font>
<font face="Arial, Verdana">#define JAM_ERROR_STEPS 500</font>
<font face="Arial, Verdana">#define JAM_MIN_STEPS 10</font>
<font face="Arial, Verdana">#define JAM_ACTION 1</font>
</font>
<font face="Arial, Verdana">#define RETRACT_DURING_HEATUP true</font>
<font face="Arial, Verdana">#define PID_CONTROL_RANGE 20</font>
<font face="Arial, Verdana">#define SKIP_M109_IF_WITHIN 2</font>
<font face="Arial, Verdana">#define SCALE_PID_TO_MAX 1</font>
<font face="Arial, Verdana">#define TEMP_HYSTERESIS 0</font>
<font face="Arial, Verdana">#define EXTRUDE_MAXLENGTH 160</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR0 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE0 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR1 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE1 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR2 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE2 {}</font>
<font face="Arial, Verdana">#define GENERIC_THERM_VREF 5</font>
<font face="Arial, Verdana">#define GENERIC_THERM_NUM_ENTRIES 33</font>
<font face="Arial, Verdana">#define HEATER_PWM_SPEED 0</font>
