<p class="MsoNormal">Debuging Host to my Firmware
communication using Repetier Host is not going well.<o:p></o:p></p>
<p class="MsoNormal">I have checked the data in
the Rx buffer, and all commands have been tested. These work with<o:p></o:p></p>
<p class="MsoNormal">the terminal program probably since
its slow manual entry. I have a 64byte
RxBuffer and <o:p></o:p></p>
<p class="MsoNormal">can preload it before
outputting "start" . That also
worked fine. However the Host<o:p></o:p></p>
<p class="MsoNormal">in ping pong modes times out
when the instruction replies with status information<o:p></o:p></p>
<p class="MsoNormal">in the following format Reply_Value ok on a single line. <o:p></o:p></p>
<p class="MsoNormal">In non ping pong mode this
seems to <o:p></o:p></p>
<p class="MsoNormal">be accepted and there are no
timeout. I wish I had a typical bootup listing to see if<o:p></o:p></p>
<p class="MsoNormal">I have a problem with output
formatting. The following boot and start sequence is<o:p></o:p></p>
<p class="MsoNormal">what I receive in the
Repetier debug window;<o:p></o:p></p>
<p class="MsoNormal"> </p>
<p class="MsoNormal">start<o:p></o:p></p>
<p class="MsoNormal">N1 M140
S0*100<o:p></o:p></p>
<p class="MsoNormal">N2 M84*29<o:p></o:p></p>
<p class="MsoNormal">ok<o:p></o:p></p>
M110*34 Restarted due to start<o:p></o:p></p>
<p class="MsoNormal">N2 M115*36<o:p></o:p></p>
<p class="MsoNormal">N4 M114*35 //WHERE IS N3, I never see it.<o:p></o:p></p>
<p class="MsoNormal">N5 M111
S6*98<o:p></o:p></p>
<p class="MsoNormal">ok (for N1)<o:p></o:p></p>
<p class="MsoNormal">N6 T0*60<o:p></o:p></p>
<p class="MsoNormal">FHamori
Version 6.1 12/6/2016 <o:p></o:p></p>
<p class="MsoNormal">X0.0 Y0.0
Z0.0 E0.0 ok ( for N2 )<o:p></o:p></p>
<p class="MsoNormal">ok (for N3)<o:p></o:p></p>
<p class="MsoNormal">N7 M80*28<o:p></o:p></p>
<p class="MsoNormal">ok (for N4)<o:p></o:p></p>
<p class="MsoNormal">ok (for N5)<o:p></o:p></p>
<p class="MsoNormal">N8 M107*45<o:p></o:p></p>
<p class="MsoNormal">N9 G28*26<o:p></o:p></p>
<p class="MsoNormal">ok (for N6)<o:p></o:p></p>
<p class="MsoNormal">ok (for N7)<o:p></o:p></p>
<p class="MsoNormal">N10 G1 Z5
F5000*53 //Problem because Z moves very
slowly?? <o:p></o:p></p>
<p class="MsoNormal">ok (for N8)<o:p></o:p></p>
<p class="MsoNormal">N11 G21*42<o:p></o:p></p>
<p class="MsoNormal">ok (for N9)<o:p></o:p></p>
<p class="MsoNormal">N12 G90*35<o:p></o:p></p>
<p class="MsoNormal">ok (for N10)<o:p></o:p></p>
<p class="MsoNormal">N13 G92
E0*117<o:p></o:p></p>
<p class="MsoNormal">ok (for N11)<o:p></o:p></p>
<p class="MsoNormal">N14 G1
Z0.35 F7800*22 (This did run?)<o:p></o:p></p>
<p class="MsoNormal">ok (for N12)<o:p></o:p></p>
<p class="MsoNormal">I dont know
if this is correctly understood by me.<o:p></o:p></p>
<p class="MsoNormal">I tried
modifying the acknowledge to be on a separate line, but nothing really changed.<o:p></o:p></p>
<p class="MsoNormal">Also an "rs10"
with no space separation never does any resend and I also "tryed rs 10"<o:p></o:p></p>
<p class="MsoNormal">which also
doesn't respond. Should it be "rs
N10"<o:p></o:p></p>
