<font face="Arial, Verdana" style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: normal;">Hi folks.</font>
<font face="Arial, Verdana">First, my seasonal greetings to everyone !</font>
I'm getting confused on how to setup my parameters to get auto-level working.
My layout of Z min endstop (inductive sensor), nozzle, bed and Z probe (optical distance sensor) is as follows:
When Z homing is done at bottom of Z-axis, I have set corresponding Z value to 25.0mm. This allows nozzle to go below (Z min endstop is a inductive switch so no collision).
Nozzle hits bed at Z = 2.5mm.
I have placed an optical Z probe on the printer head. The bottom of this sensor is about 85mm above the tip of the nozzle.
Z probe has been adjusted and it triggers (sees bed plane) at Z = 33.0mm
My problem is how to configure Z probe in firmware (I'm using firmware 0.92.9 and host 1.62) ??????
I cannot find meaning in EEPROM values....
This is what I have now:
<epr pos="133" type="3" value="-160.000">X min pos</epr>
<epr pos="137" type="3" value="-195.000">Y min pos</epr>
<epr pos="141" type="3" value="25.000">Z min pos</epr>
<epr pos="145" type="3" value="360.000">X max length</epr>
<epr pos="149" type="3" value="390.000">Y max length</epr>
<epr pos="153" type="3" value="290.000">Z max length</epr>
<epr pos="51" type="3" value="1000.000">X-axis acceleration</epr>
<epr pos="55" type="3" value="1000.000">Y-axis acceleration</epr>
<epr pos="59" type="3" value="100.000">Z-axis acceleration</epr>
<epr pos="63" type="3" value="1000.000">X-axis travel acceleration</epr>
<epr pos="67" type="3" value="1000.000">Y-axis travel acceleration</epr>
<epr pos="71" type="3" value="100.000">Z-axis travel acceleration</epr>
<epr pos="1032" type="3" value="0.000">Acceleration factor at top</epr>
<epr pos="1024" type="3" value="0.000">Coating thickness</epr>
<epr pos="808" type="3" value="120">Z-probe height</epr>
<epr pos="929" type="3" value="87">Max. z-probe - bed dist.</epr>
<epr pos="812" type="3" value="2.000">Z-probe speed</epr>
<epr pos="840" type="3" value="150.000">Z-probe x-y-speed</epr>
<epr pos="800" type="3" value="0.000">Z-probe offset x</epr>
<epr pos="804" type="3" value="0.000">Z-probe offset y</epr>
<epr pos="816" type="3" value="0.000">Z-probe X1</epr>
<epr pos="820" type="3" value="0.000">Z-probe Y1</epr>
<epr pos="824" type="3" value="0.000">Z-probe X2</epr>
<epr pos="828" type="3" value="0.000">Z-probe Y2</epr>
<epr pos="832" type="3" value="0.000">Z-probe X3</epr>
<epr pos="836" type="3" value="0.000">Z-probe Y3</epr>
<epr pos="1036" type="3" value="0.000">Z-probe bending correction A</epr>
<epr pos="1040" type="3" value="0.000">Z-probe bending correction B</epr>
<epr pos="1044" type="3" value="0.000">Z-probe bending correction C</epr>
<epr pos="880" type="0" value="0">Autolevel active (1/0)</epr>
When I execute G30 command from Z = 50.0mm, Z axis moves slowly down, Z sensor triggers, Z axis returns to 50.0mm and I get this message in log :
Z-probe:NAN X:0.00 Y:0.00
I have tried to change "Z-probe height" and "Max. z-probe - bed dist." but I do not know what these exactly do ...
Please, can anyone explain to me what these values correspond to my layout and/or how get things work correctly ?
Thank you
