<font face="Arial, Verdana">I am completely lost about the z leveling.</font>
Seems the probe interferes between the fact it is used as endstop and as bed detection...
The probe is about 1 mm up the nozzle.
When I home z, the nozzle nearly touch the bed
When I launch a print task, after auto leveling, the nozzle start to print 3 or 4 mm away of the bed.
I am missing something, but I can't tell what.
Here's a copy of my configuration.h
If someone can have a look at it it would be nice.
</font>
<font face="Arial, Verdana">#define NUM_EXTRUDER 2</font>
<font face="Arial, Verdana">#define MOTHERBOARD 33</font>
<font face="Arial, Verdana">#include "pins.h"</font>
</font>
<font face="Arial, Verdana">// ################## EDIT THESE SETTINGS MANUALLY ################</font>
<font face="Arial, Verdana">// ################ END MANUAL SETTINGS ##########################</font>
</font>
<font face="Arial, Verdana">#undef FAN_BOARD_PIN</font>
<font face="Arial, Verdana">#define FAN_BOARD_PIN -1</font>
<font face="Arial, Verdana">#define BOARD_FAN_SPEED 255</font>
<font face="Arial, Verdana">#define FAN_THERMO_PIN -1</font>
<font face="Arial, Verdana">#define FAN_THERMO_MIN_PWM 128</font>
<font face="Arial, Verdana">#define FAN_THERMO_MAX_PWM 255</font>
<font face="Arial, Verdana">#define FAN_THERMO_MIN_TEMP 45</font>
<font face="Arial, Verdana">#define FAN_THERMO_MAX_TEMP 60</font>
<font face="Arial, Verdana">#define FAN_THERMO_THERMISTOR_PIN -1</font>
<font face="Arial, Verdana">#define FAN_THERMO_THERMISTOR_TYPE 1</font>
<font face="Arial, Verdana">#undef Z_MIN_PIN</font>
<font face="Arial, Verdana">#define Z_MIN_PIN 12</font>
</font>
<font face="Arial, Verdana">//#define EXTERNALSERIAL use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.</font>
<font face="Arial, Verdana">// Uncomment the following line if you are using Arduino compatible firmware made for Arduino version earlier then 1.0</font>
<font face="Arial, Verdana">// If it is incompatible you will get compiler errors about write functions not being compatible!</font>
<font face="Arial, Verdana">//#define COMPAT_PRE1</font>
<font face="Arial, Verdana">#define BLUETOOTH_SERIAL -1</font>
<font face="Arial, Verdana">#define BLUETOOTH_BAUD 115200</font>
<font face="Arial, Verdana">#define MIXING_EXTRUDER 0</font>
</font>
<font face="Arial, Verdana">#define DRIVE_SYSTEM 0</font>
<font face="Arial, Verdana">#define XAXIS_STEPS_PER_MM 80</font>
<font face="Arial, Verdana">#define YAXIS_STEPS_PER_MM 160</font>
<font face="Arial, Verdana">#define ZAXIS_STEPS_PER_MM 1600</font>
<font face="Arial, Verdana">#define EXTRUDER_FAN_COOL_TEMP 50</font>
<font face="Arial, Verdana">#define PDM_FOR_EXTRUDER 0</font>
<font face="Arial, Verdana">#define PDM_FOR_COOLER 0</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 30</font>
<font face="Arial, Verdana">#define DECOUPLING_TEST_MIN_TEMP_RISE 1</font>
<font face="Arial, Verdana">#define KILL_IF_SENSOR_DEFECT 0</font>
<font face="Arial, Verdana">#define RETRACT_ON_PAUSE 2</font>
<font face="Arial, Verdana">#define PAUSE_START_COMMANDS ""</font>
<font face="Arial, Verdana">#define PAUSE_END_COMMANDS ""</font>
<font face="Arial, Verdana">#define SHARED_EXTRUDER_HEATER 1</font>
<font face="Arial, Verdana">#define EXT0_X_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Y_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_Z_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT0_STEPS_PER_MM 85</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_TYPE 1</font>
<font face="Arial, Verdana">#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_HEATER_PIN HEATER_0_PIN</font>
<font face="Arial, Verdana">#define EXT0_STEP_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE 1</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_ENABLE_ON 0</font>
<font face="Arial, Verdana">#define EXT0_MIRROR_STEPPER 0</font>
<font face="Arial, Verdana">#define EXT0_STEP2_PIN ORIG_E0_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT0_DIR2_PIN ORIG_E0_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT0_INVERSE2 0</font>
<font face="Arial, Verdana">#define EXT0_ENABLE2_PIN ORIG_E0_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT0_MAX_FEEDRATE 50</font>
<font face="Arial, Verdana">#define EXT0_MAX_START_FEEDRATE 20</font>
<font face="Arial, Verdana">#define EXT0_MAX_ACCELERATION 2000</font>
<font face="Arial, Verdana">#define EXT0_HEAT_MANAGER 3</font>
<font face="Arial, Verdana">#define EXT0_WATCHPERIOD 1</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MAX 230</font>
<font face="Arial, Verdana">#define EXT0_PID_INTEGRAL_DRIVE_MIN 40</font>
<font face="Arial, Verdana">#define EXT0_PID_PGAIN_OR_DEAD_TIME 7</font>
<font face="Arial, Verdana">#define EXT0_PID_I 2</font>
<font face="Arial, Verdana">#define EXT0_PID_D 40</font>
<font face="Arial, Verdana">#define EXT0_PID_MAX 255</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_K 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_L 0</font>
<font face="Arial, Verdana">#define EXT0_ADVANCE_BACKLASH_STEPS 0</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_TEMP 150</font>
<font face="Arial, Verdana">#define EXT0_WAIT_RETRACT_UNITS 0</font>
<font face="Arial, Verdana">#define EXT0_SELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_DESELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_PIN -1</font>
<font face="Arial, Verdana">#define EXT0_EXTRUDER_COOLER_SPEED 255</font>
<font face="Arial, Verdana">#define EXT0_DECOUPLE_TEST_PERIOD 12000</font>
<font face="Arial, Verdana">#define EXT0_JAM_PIN -1</font>
<font face="Arial, Verdana">#define EXT0_JAM_PULLUP 0</font>
<font face="Arial, Verdana">#define EXT1_X_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT1_Y_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT1_Z_OFFSET 0</font>
<font face="Arial, Verdana">#define EXT1_STEPS_PER_MM 85</font>
<font face="Arial, Verdana">#define EXT1_TEMPSENSOR_TYPE 1</font>
<font face="Arial, Verdana">#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN</font>
<font face="Arial, Verdana">#define EXT1_HEATER_PIN HEATER_0_PIN</font>
<font face="Arial, Verdana">#define EXT1_STEP_PIN ORIG_E1_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT1_DIR_PIN ORIG_E1_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT1_INVERSE 0</font>
<font face="Arial, Verdana">#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT1_ENABLE_ON 0</font>
<font face="Arial, Verdana">#define EXT1_MIRROR_STEPPER 0</font>
<font face="Arial, Verdana">#define EXT1_STEP2_PIN ORIG_E1_STEP_PIN</font>
<font face="Arial, Verdana">#define EXT1_DIR2_PIN ORIG_E1_DIR_PIN</font>
<font face="Arial, Verdana">#define EXT1_INVERSE2 0</font>
<font face="Arial, Verdana">#define EXT1_ENABLE2_PIN ORIG_E1_ENABLE_PIN</font>
<font face="Arial, Verdana">#define EXT1_MAX_FEEDRATE 50</font>
<font face="Arial, Verdana">#define EXT1_MAX_START_FEEDRATE 20</font>
<font face="Arial, Verdana">#define EXT1_MAX_ACCELERATION 2000</font>
<font face="Arial, Verdana">#define EXT1_HEAT_MANAGER 3</font>
<font face="Arial, Verdana">#define EXT1_WATCHPERIOD 1</font>
<font face="Arial, Verdana">#define EXT1_PID_INTEGRAL_DRIVE_MAX 230</font>
<font face="Arial, Verdana">#define EXT1_PID_INTEGRAL_DRIVE_MIN 40</font>
<font face="Arial, Verdana">#define EXT1_PID_PGAIN_OR_DEAD_TIME 7</font>
<font face="Arial, Verdana">#define EXT1_PID_I 2</font>
<font face="Arial, Verdana">#define EXT1_PID_D 40</font>
<font face="Arial, Verdana">#define EXT1_PID_MAX 255</font>
<font face="Arial, Verdana">#define EXT1_ADVANCE_K 0</font>
<font face="Arial, Verdana">#define EXT1_ADVANCE_L 0</font>
<font face="Arial, Verdana">#define EXT1_ADVANCE_BACKLASH_STEPS 0</font>
<font face="Arial, Verdana">#define EXT1_WAIT_RETRACT_TEMP 150</font>
<font face="Arial, Verdana">#define EXT1_WAIT_RETRACT_UNITS 0</font>
<font face="Arial, Verdana">#define EXT1_SELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT1_DESELECT_COMMANDS ""</font>
<font face="Arial, Verdana">#define EXT1_EXTRUDER_COOLER_PIN -1</font>
<font face="Arial, Verdana">#define EXT1_EXTRUDER_COOLER_SPEED 255</font>
<font face="Arial, Verdana">#define EXT1_DECOUPLE_TEST_PERIOD 12000</font>
<font face="Arial, Verdana">#define EXT1_JAM_PIN -1</font>
<font face="Arial, Verdana">#define EXT1_JAM_PULLUP 0</font>
</font>
<font face="Arial, Verdana">#define FEATURE_RETRACTION 1</font>
<font face="Arial, Verdana">#define AUTORETRACT_ENABLED 0</font>
<font face="Arial, Verdana">#define RETRACTION_LENGTH 3</font>
<font face="Arial, Verdana">#define RETRACTION_LONG_LENGTH 13</font>
<font face="Arial, Verdana">#define RETRACTION_SPEED 40</font>
<font face="Arial, Verdana">#define RETRACTION_Z_LIFT 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0</font>
<font face="Arial, Verdana">#define RETRACTION_UNDO_SPEED 20</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_X_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Y_POS 0</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_Z_ADD 2</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_REHOME 1</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_SHORTRETRACT 5</font>
<font face="Arial, Verdana">#define FILAMENTCHANGE_LONGRETRACT 50</font>
<font face="Arial, Verdana">#define JAM_STEPS 220</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_STEPS 320</font>
<font face="Arial, Verdana">#define JAM_SLOWDOWN_TO 70</font>
<font face="Arial, Verdana">#define JAM_ERROR_STEPS 500</font>
<font face="Arial, Verdana">#define JAM_MIN_STEPS 10</font>
<font face="Arial, Verdana">#define JAM_ACTION 1</font>
</font>
<font face="Arial, Verdana">#define RETRACT_DURING_HEATUP true</font>
<font face="Arial, Verdana">#define PID_CONTROL_RANGE 20</font>
<font face="Arial, Verdana">#define SKIP_M109_IF_WITHIN 2</font>
<font face="Arial, Verdana">#define SCALE_PID_TO_MAX 0</font>
<font face="Arial, Verdana">#define TEMP_HYSTERESIS 0</font>
<font face="Arial, Verdana">#define EXTRUDE_MAXLENGTH 160</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR0 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE0 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR1 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE1 {}</font>
<font face="Arial, Verdana">#define NUM_TEMPS_USERTHERMISTOR2 0</font>
<font face="Arial, Verdana">#define USER_THERMISTORTABLE2 {}</font>
<font face="Arial, Verdana">#define GENERIC_THERM_VREF 5</font>
<font face="Arial, Verdana">#define GENERIC_THERM_NUM_ENTRIES 33</font>
<font face="Arial, Verdana">#define HEATER_PWM_SPEED 0</font>
</font>
<font face="Arial, Verdana">// ############# Heated bed configuration ########################</font>
</font>
<font face="Arial, Verdana">#define HAVE_HEATED_BED 1</font>
<font face="Arial, Verdana">#define HEATED_BED_MAX_TEMP 120</font>
<font face="Arial, Verdana">#define SKIP_M190_IF_WITHIN 3</font>
<font face="Arial, Verdana">#define HEATED_BED_SENSOR_TYPE 1</font>
<font face="Arial, Verdana">#define HEATED_BED_SENSOR_PIN TEMP_1_PIN</font>
<font face="Arial, Verdana">#define HEATED_BED_HEATER_PIN HEATER_1_PIN</font>
<font face="Arial, Verdana">#define HEATED_BED_SET_INTERVAL 5000</font>
<font face="Arial, Verdana">#define HEATED_BED_HEAT_MANAGER 0</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 196</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_IGAIN 33</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_DGAIN 290</font>
<font face="Arial, Verdana">#define HEATED_BED_PID_MAX 255</font>
<font face="Arial, Verdana">#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000</font>
<font face="Arial, Verdana">#define MIN_EXTRUDER_TEMP 150</font>
<font face="Arial, Verdana">#define MAXTEMP 275</font>
<font face="Arial, Verdana">#define MIN_DEFECT_TEMPERATURE 5</font>
<font face="Arial, Verdana">#define MAX_DEFECT_TEMPERATURE 290</font>
</font>
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 1
#define Z_PROBE_PIN 12
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 40
#define Z_PROBE_Y1 40
#define Z_PROBE_X2 140
#define Z_PROBE_Y2 40
#define Z_PROBE_X3 40
#define Z_PROBE_Y3 140
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
</font>
