I don't think so since the Windows version of Repetier-Host works fine. I did not compile the firmware; it's provided pre-compiled by Geeetech. The Windows version calls it a Rostock whereas the Mac version calls it a Delta although this may not be significant.
Also, the Mac version requires x/y values for the printer shape but changes the values for a total diameter of 200 even though I set the diameter to 170. I have x and y set to +/-100 and the home to 0. Home for z is set to max which is specified as 220 mm. Bug in total diameter aside, are these settings correct?
I have confirmed that G28 works to send the printer home. Does the Mac version issue that code when the home button is pressed? If not, what g-code is sent?
Thanks.
--Dave
