So fat it looks fine. What is happening after that? If print stops logging continues in connected.log. We need the comlete part to see the truth, e.g. if printer just reset.
You can print with dry run enabled so you do not waste filament. If it is printer related it might not happen then. Printer realted problems are often also power usage related.
