<font face="Arial, Verdana">#define NUM_MOTOR_DRIVERS 0</font>
<font face="Arial, Verdana">// #define MOTOR_DRIVER_x StepperDriver<int stepPin, int dirPin, int enablePin,bool invertDir, bool invertEnable>(float stepsPerMM,float speed)</font>
<font face="Arial, Verdana">#define MOTOR_DRIVER_1(var) StepperDriver<E1_STEP_PIN, E1_DIR_PIN, E1_ENABLE_PIN, false, false> var(100.0f,5.0f)</font>
<int steppin,="" int="" dirpin,="" enablepin,bool="" invertdir,="" bool="" invertenable="" style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: normal;"><e1_step_pin, e1_dir_pin,="" e1_enable_pin,="" false,="" false="">
</e1_step_pin,></int>
<int steppin,="" int="" dirpin,="" enablepin,bool="" invertdir,="" bool="" invertenable="" style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: normal;"><e1_step_pin, e1_dir_pin,="" e1_enable_pin,="" false,="" false="">Some motors need invertEnable true.
Also in brackets you need to separate with , not with . as you did. Last thing is speed. This all works without acceleration so only slow speeds are supposed to work, not speeds like 100mm/s. That will give you only a humming motor and loose all steps.
