<font face="Arial, Verdana">Yes this build is designed for my printer. but now I downloaded a clean firmware and got the error message:
</font>
</font>
<font face="Arial, Verdana">In file included from C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\HAL.h:83:0,</font>
</font>
<font face="Arial, Verdana"> from C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\Repetier.h:539,</font>
</font>
<font face="Arial, Verdana"> from C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\Printer.cpp:19:</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\Printer.cpp: In static member function 'static void Printer::setup()':</font>
</font>
<font face="Arial, Verdana">fastio.h:34: error: 'DIO49_DDR' was not declared in this scope</font>
</font>
<font face="Arial, Verdana"> #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= MASK(DIO ## IO ## PIN); } while (0)</font>
</font>
<font face="Arial, Verdana"> ^</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\fastio.h:54:26: note: in expansion of macro '_SET_INPUT'</font>
</font>
<font face="Arial, Verdana"> #define SET_INPUT(IO) SET_INPUT(IO)</font>
</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\Printer.cpp:823:5: note: in expansion of macro 'SET_INPUT'</font>
</font>
<font face="Arial, Verdana"> SET_INPUT(SDCARDDETECT);</font>
</font>
</font>
</font>
</font>
</font>
<font face="Arial, Verdana">fastio.h:34: error: 'DIO49_PIN' was not declared in this scope</font>
</font>
</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\fastio.h:17:30: note: in definition of macro 'MASK'</font>
</font>
<font face="Arial, Verdana"> #define MASK(PIN) (1 << PIN)</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
<font face="Arial, Verdana">fastio.h:29: error: 'DIO49_WPORT' was not declared in this scope</font>
</font>
<font face="Arial, Verdana"> #define _WRITE(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= MASK(DIO ## IO ## PIN); }; } while (0)</font>
</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\fastio.h:49:37: note: in expansion of macro '_WRITE'</font>
</font>
<font face="Arial, Verdana"> #define PULLUP(IO,v) WRITE(IO, v)</font>
</font>
</font>
<font face="Arial, Verdana">C:\Users\Pavel\AppData\Local\Temp\build5c8125c19a4bf5cf8355714a867c5469.tmp\sketch\Printer.cpp:824:5: note: in expansion of macro 'PULLUP'</font>
</font>
<font face="Arial, Verdana"> PULLUP(SDCARDDETECT, HIGH);</font>
</font>
</font>
<font face="Arial, Verdana">fastio.h:29: error: 'DIO49_PIN' was not declared in this scope</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
</font>
<font face="Arial, Verdana"> #define _WRITE(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= MASK(DIO ## IO ## _PIN); }; } while (0)</font>
</font>
</font>
</font>
</font>
</font>
</font>
<font face="Arial, Verdana"> #define PULLUP(IO,v) _WRITE(IO, v)</font>
</font>
</font>
</font>
</font>
</font>
<font face="Arial, Verdana">Use the SPI library version 1.0 from the folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI </font>
<font face="Arial, Verdana">exit status 1</font>
<font face="Arial, Verdana">'DIO49_DDR' was not declared in this scope</font>
</font>
what now? sorry, but I just started to learn the firmware, and my knowledge is not enough to solve this problem
