Repetier Firmware
MKS GENS 1.4 Board
CORE XY
http://www.thingiverse.com/thing:651117</div><div><br/></div><div><br/></div><div>I recently made a COREXY printer everything has been smooth sailing for me until I got to the endstops I've been stuck on the endstops for about 5 days now just when i think I had everything correct I change one or two lines and they all start going the wrong way and homing the wrong way. I'm using mechanical endstops ( 2 wire blk/red one on each end) and have them plugged into the min slots on my MKS 1.4. At the moment the X axis is homing in the correct direction (to the right)but the movement is mirrored If I move left it goes right and vise versa the Y axis however is moving correctly but it wont home at all when I hit home Y it just moves a little bit and stops the Z axis is only working in one direction which is also inverted If I move down it goes up. My other question is since I have a core xy setup my Z axis seperate would have to move all the way up to the top to home how would I set up printing so it comes back down as the layers increase do I invert this? any help or direction would be appreciated if anyone has the same board or same setup I wouldn't mind taking a glace at your firmware and see how to do things correctly.
what I'm trying to accomplish
X axis end stop home to the right of printer
Y axis end stop home to the back of printer (move forward)
Z axis end stop home to the top of the printer
my config.h
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 120
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
<strike></strike>
x
