I'm drawing up a dual Z max endstops. I'm using slitted optical switches so the bed can move past Z max without hitting anything depending on design.
Using a Z max offset would simplify my design so I could just have fixed position on the switches.
E.g. I have 300mm Z and let the Z max trigger at 295mm. Would I be able to use the last 5mm and still have the printer stop any movement past 300mm?
