<font face="Arial, Verdana">Ok, Thank you for your answer.</font>
Right now i'm trying to figure out a most easy and on the other hand stable way of fixing the build plate to the 3 or 4 rods.
It is not so simple as the every plate/rod mount point needs to have flexibility to give plane move for bed when other rod is moved in leveling action.
It has to be some kind of connection like some kind of coupling bar / pull rod.
<font face="Lato, Helvetica, Arial, sans-serif">I was thinking about one more solution/addon to the printing bed - to mount accelerometer module and use that for additional leveling data, or even two one on the bed it self and second on frame, and to calculate differences in those two, but that was just an idea. I do not know if it could be useful.</font>
</font>
<font face="Lato, Helvetica, Arial, sans-serif">I,ve got a frame already designed for 3 steppers for Z, two in front, and third in back, I think that 3 steppers will be good choice because</font> additional 2 steppers are needed for coreXY, and next 2 steppers for printing head (dual head)
So it takes 7 steppers and it is hard to find electronics that could support 7 stepper drivers on the market to build the prototype fast.
<font face="Lato, Helvetica, Arial, sans-serif">4 steppers in Z would make it even harder to build....</font>
</font>
<font face="Lato, Helvetica, Arial, sans-serif">Do you know any good electronics with 7 or 8 stepper drivers ?</font>
</font>
