ap742 Morning Guys. I am bit clueless here. so gutted my fried da vinci and ordered MKS Gen V1.4 whatever that is. ... just because it was compact and had nice connectors . mistake ?I have Ramps 1.4 on my other delta project I have no issues loading firmware BUT this MKS Gen V1.4 is not working I loaded test code and moves my axis around But when I load Marlin and enable Screen . screen won't come on. I wonder if anyone can explain what that MKS GEN V1.4 is and is there step by step for dummies somehwere ? Thank You
Repetier Wrong forum if you seek help for Marlin. This is the repetier-firmware forum, which is completely different.No screen = wrong display selected in configuration I'd say.
Repetier From their description the RAMPS 1.4 settings should just work.The displays often have problems with bad cables as a alternative reason for the problem. So maybe use a multimeter to test all lines are working. Check pcb for bad solderings/bridges.
