Hi, I realize that there have been a fe discussions regarding similar issues but none of those seem to solve my problem. Apologies if I missed the answer somewhere.
I can't get past 185 degrees on my extruder. I'm trying to heat it up to 200 but it stops at 180. After about 10 minutes the temperature rises to roughly 185 and remains stable.
This is with EXT0_HEAT_MANAGER 1 . With EXT0_HEAT_MANAGER 3 the temp goes up to 170 degrees and stays there.
I've tried altering PID values but nothing seems to help.The max temps in host are set correctly as well.
This is the relevant poriton of configuration.h (eeprom disabled):
div>
define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 66.67
#define YAXIS_STEPS_PER_MM 66.67
#define ZAXIS_STEPS_PER_MM 2560
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 96.45
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_MAX_ACCELERATION 4000
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 255
#define EXT0_PID_INTEGRAL_DRIVE_MIN 0
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_DECOUPLE_TEST_PERIOD 200000
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0div>
I'm out of ideas so any help will be appreciated,.
