Repetier/Marlin.
Hi. I am trying to use Repetier with a Marlin-based printer, but the print keeps starting with the mechanical endstops as the reference rather than the offset soft endstops. Can anyone advise if this is a Marlin problem, or a Repetier one ? Sending G28 sends the carriage to -10, -10, -3 on the printer display. 0, 0, 0 Is the reference I want for printing
G851 provoked an "Unknown Command, so I used M428, but no change
Snip
The following strategy must be followed to specify the Z offset:
Heat your printer up to your printing temperature and allow a few minutes for it to expand and settle
Reset the existing Z-offset to zero M851 Z0
Home all axes G28
Move the nozzle to the middle of the bed G1 X110 Y110 (if your bed is 220 x 220)
Turn off the software endstops with M211 S0
Move the nozzle down so it is just gripping a piece of standard printer paper
Set the Z-offset to the displayed value. E.g. if the printer displays a Z-Value of -1.23 enter M851 Z-1.23
Store it to the EEPROM M500
Important notice! Enable the endstops again with M211 S1 or the printer head will collide with the bed on the next G28 command
