No that is not what the fields are for. You can enter an existing domain there. All it does is on home screen to show this as access url.
If you are using our pi image you can set the hostname of the server in network settings and since it is running bonjour service you can access it with "hostname.local" on all devices in your network that support this standard like iphone. Only watch out all images have be default same hostname so you need different names if you run multiple instances.
