OK, now I am confused again... LOL
I know I am missing something very fundamental, and it is making me mental!
I measured exactly the middle of the 200x200 bed and marked it on the blue tape. I KNOW where the center of the bed is.
I created a cross object (X marks the spot) and opened it with Repetier-Host application. Using the picture area I placed the object directly over the Center indicator on the display. So, theoretically, when I print it should be in the middle of the bed.
I changed the printer setting to +20 by changing the setting button up near the "EASY BUTTON" I selected the Printer tab and there on the screen is a "Park Position" for X, X and Z. I put the value 20 into the Y entry area.
This did not help. It still printed 20 mm off center.
I then went into the Slic3r Configuration and under Printer setting, entered a -20 into the y-axis. Now the picture diagram showed the extruder at the position of where it physically is at when I home the printer.
Saved changes, re-sliced object and it still showed that it was in the center of the print bed. Same thing, it printed 20 mm off. Same spot as before.
So for grins, I changed the value of -20 to +20 on the Slic3r Configuration. Now the y axis start is above the box in the display. Printed again and it printed in the same spot again.
So I looked into the g-code, and it is printing the number for the y axis is exactly where it is printing. So the printer is going to where it should (per the g-code). Somehow, my 20mm offset has got to be added to the g-code so that it prints in the direct center. How do I do that?
Thanks, with a smile,
Israel
BTY, I changed everything back to 0 both in the printer setting and the Slic3r Config. awaiting your suggestion.
