Hi everyone,
I’ve got some special requests/questions again.
Is it possible to access the server's GUI via HTTP(s) from another system?
Background:
My server is currently running on a Pi 4 with an SSD and an attached 5" touchscreen.
Since I’m planning to hook up three printers to it soon, the cable clutter is becoming a real nuisance. So, I’m considering an alternative.
Idea:
I have a spare 15" FHD touchscreen. It would be perfect as a "control center." To move it around the room (more or less) freely, I’d like to connect a Radxa Zero (left over from another project) to it; this would simply connect to the LAN via Wi-Fi. Meanwhile, I’d mount the Pi 4 server—along with all the other gear (power supplies, USB hub, power strips, LAN switch, etc.)—to the wall. Then, I’d just pull up the server GUI via HTTP on the Radxa to display it on the 15" screen, while sending the touchscreen commands back the other way...
Will that work?
Addendum:
I realize I can access Repetier via port 3344; that’s how I always do it from the other room.
What I’m referring to now—in addition to that—is what is displayed locally on the small screen right on the server...
