<font face="Arial, Verdana" size="2">Thank-you for the tips...</font>
I have recalibrated things again following your advice...and things are a bit better.
I am wondering however, it is possible that shifting extruders while a Delta is homed causes some problem, like end stop
collision? I added 10mm to the back away last time I built the firmware but maybe this was not enough (though better that the 5mm I used previously). I notice now that my start code which issues T0, T1 commands (is that the right way to do this is or are there M or G commands) to change and heat/prime the extruders seems to cause a 'clunking sound' not the smooth transition from ext0 to ext1 and back. If I remove these the result seems to be more level travel over the bed during print.
Also I get odd sounds when I adjust the travel accelerations in the start code, even without the extruder changes. I use something like this <font face="Helvetica Neue" size="2">M201 X500 Y500 which I assume is correct for Repetier firmware as opposed to the M204 some other systems use.</font>
</font>
<font size="2"><font face="Arial, Verdana" size="2" style="font-family: 'Helvetica Neue';">Thanks </font><font face="Helvetica Neue">again</font><font face="Arial, Verdana" size="2"><font face="Helvetica Neue"> for all </font>the<font face="Helvetica Neue"> work and assistance.</font></font></font>
