Irregularly, the firmware restarts stopping the printer.
Is there a way to display the origin of the reset?
What are the possibilities apart from perhaps the watchdog if temperature loop is not called every second.
In the case of the temperature loop, does this concern the bed and the hotend?
I mounted a BambuLab A1 compatible hotend, I configured the sensor as follows:
EXT0_TEMPSENSOR_TYPE 14
could this be the origin? It is possible that it was from this moment that the problem appeared...
This also happens when the printer is idle.
