For a long time I stayed with firmware 1.0.3, then recently I made a modification with web configurator 1.0.4.
The new configuration.h file looks fine and the firmware seems to work as well.
Today I wanted to make a change again, but unable to reload the configuration.h file... none of the settings I use are loaded. I tried several versions of this file without success.
Any idea, any solution other than starting from zero?
Thank you in advance
