Hi
I am almost done building my own delta 3d printer, evereything works exept the extruder motor.
Repetier host does not show errors. I have set min extruder temp to 0 in configuration.h, I all-ways heat it up to 200 under testing. Dry run is off and the step/mm speed is low and should work.
I have testet evereything in the hardware, including the motor, stepstick and the eletrical connection on the pcb boards are also all-right and not short circuitet to anything.
Evereything is correct in pins.h, and I have tryed moving to second extruder slot without getting any further.
Now I have attached my oscilloscope and the step and dir signals is allright and ticking, but enable is allways pulled high and newer goes low to enable the driver.
My question is short, what can prevent the driver from enabeling? what do I have to check.
I have spend over a week on this and I am out of ideas of where to look. The code is very large and I am mostly a hardware person.
I use newest stable arduino ide, arduino mega + Ramps 1.4, repetier firmware 0.91
Also the enable cold extrusion command does not help
I have searched on everey forum but have not found anything that works for me
I hope somebody has an idea
Else, what will happen if I bypass the firmware regarding the enable pin, and manually enable the driver permantly. Will that screw evereyting up, and make bad prints?
