I tried to re-activate a RepetiereServer on a respberry pi 3 A+
Do not know which version, the download link of the purchase lead me to Repetier-Server_1_3_0b.zip.
The raspberry boots, but does not connect to a WiFi. Maybe I changed the WiFi name ... do not remember.
I can see the accesspoint of the raspberry, but when connecting with my phone, it does not get an IP address from the DHCP.
When setting it up for a fixed IP with 10.10.10.50 as own adress, 1010.10.1 as gateway and DNS and 24 as subnet, I got connected, but cannot connect to 10.10.10.1:3344 or anything.
I connected a monitor via HDMI, a mouse and a keyboard and I can see that it boots into the touchscreen interface of RepetierServer.
I cannot press escape during bootup to see a shell output.
I can't do anything with the keyboard, except Alt+Tab, which changes tasks, but RepetierServer is the only one.
I do not habe a mouse pointer, but when moving the mouse I get rarely mostly the most right symbol to change color. And this is "Shutdown". I did geht some other things, like changing the language, but I do not get the settings to access the network settings.
I am tryinfg for hours without a mouse pointer...
I tried to manipulate the files of the FAT32 partition wpa_supplicant.conf an repetier-serup.txt.
I set the WPA security to 1 and later to 0, but had no luck getting an IP (As I mentioned, connecting with own fixed IP happened, but no connection to repetierserver on 10.10.10.1 Maybe it is set to another IP.)
I put the correct country shortcut, WiFI Name and the password into wpa_supplicant.conf on the FAT32 partition, but no luck.
How does the image handle these two versions? Will the FAT32 versions of those files be copied over the linux files when booting?
I also tried it putting it into this file of the linux partition but had no read permission on a linux PC. Need to retry with sudo nano.
The server is running as I can see on the directly connected monitor, but I do not get a connection.
Where in the linux system can I look to see, what it tries to connect? In the wpa_supplicant.conf?
Where would I find an fixed IP setting in the linux filesystem?
I am thinking to setup a new image, but the one license of repetierServer would be lost and I have to setup many things.
On the FAT32 partition there is a backup folder and there are some backup files on the root. Can I use these on a new server setup to get my printer settings back?
Burt first I would like to connect directly to the accesspoint with my phone and setup a new WiFI...
