I installed Repetier Host on a new computer and I had to update the built in Prusaslicer, because my config package was stored in newer version. When I try to run slicing for Prusa Mini, it produces binary gcode. I disabled the option from Repetier Host and running PrusaSlicer directly (if I understand things correctly, the settings are stored in different locations. But when I run the slicing, I still get binary code (I see in the log it runs with another ini file (slic3r something.ini - which I think is generated for each session?). It looks like the newest PrusaSlicer defaults to binary gcode when not receiving instruction not to do so. Is there any workaround for this? Trying to render the binary code makes Repetier Host unresponsive. The actual binary gcode could work, but then it would not show up as preview in my server either.
